What Stator Do I Have?
26 replies to this topic
#1 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted October 28, 2012 - 07:19 PM
I need a new stator for the '71. I looked and there are a few different styles. I don't know if I have a 1.5 amp or 3 amp set-up. How can I figure this out and what else might I need to know?
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted October 28, 2012 - 08:15 PM
See if this helps. All I have are two B/S styles and a Kohler.
Dual Stator
Single wire Stator
15A Stator http://www.youtube.com/watch?v=PRqo4kiuqlA
#3 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted October 29, 2012 - 07:55 AM
Kohler used a 10 or a 15 amp.The 10 amp had three terminals in a row and the 15 amp had two and one below.The solid state ignition used a stator with an extra wire.
#4 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 02, 2012 - 08:02 PM
Are you talking about the terminals on the rectifier? If so, I have two terminals and one below that.
#5 olcowhand ONLINE
  • 41,126 Thanks
  • 31,411 posts
Posted November 02, 2012 - 08:37 PM
Kohler also had a 1.25 amp, and a 3 amp stator. The 1.25 amp was for charging only, while the 3 amp stator was for lighting & charge circuits.
If your stator has a single black wire with an inline diode, then you have the 1.25 amp system. If it has this black wire AND a yellow wire, then it's the 3 amp system, and the yellow wire is 70 watts AC for headlight operation.
Kohler also had a 10 amp, 15 amp, 25 amp, and even a 30 amp system. The 10, 15, & 25 amp stators all had twin black leads, while the 30 amp had twin black & twin red leads.
#6 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 03, 2012 - 04:09 PM
Ok, I am officially confused! From the stator I have two red leads. What am I looking for now?
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted November 03, 2012 - 04:24 PM
can you post the model number off the engine, it may help us narrow down the proper stator/
#8 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 03, 2012 - 04:37 PM
I dont know why I always forget that? It is a K321S and the spec number is 601326
  • larrybl said thank you
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted November 03, 2012 - 06:15 PM
What I found here. http://www.messicks.com/NH/9246.aspx
K321S needs KOH237277 10A 3 prong (Call)
K321AQS needs KOH237879 15A 2 Prong "5-1/2" ($131.57)
#10 olcowhand ONLINE
  • 41,126 Thanks
  • 31,411 posts
Posted November 03, 2012 - 06:58 PM
You likely have a 10 or 15 amp stator. Can you post a pic of your stator?
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted November 03, 2012 - 07:07 PM
Ryan313, does it look like this?
#12 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 03, 2012 - 07:45 PM
Not with it still on the engine! I will have to take it off eventually, so I will get to it and post a picture when I get a chance to work on it.
#13 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 05, 2012 - 08:09 PM
I got a chance to get to the stator. Here is a picture of it.
In hoping to solve one problem, I discovered two more, and created another! With the covers off I saw that there was oil coming from the head. So, I will need a head gasket. I took the head off and saw a lot of carbon built up! And when taking off the stator I stripped a screw!
Here are pictures of the head. What is the best way to clean it?
In the pictures, you can see the oil stains on the head where it leaks. I don't think a head gasket will be hard to find, but do you guys have any suggestions?
#14 olcowhand ONLINE
  • 41,126 Thanks
  • 31,411 posts
Posted November 05, 2012 - 08:19 PM
Definitely not a 1.25 or 3 amp! That is a 15amp stator. Usually they have black leads, but maybe it was a PK thing with the red. You should have had a regulator that those leads connected to???? Or has it ever charged since you had it?
I usually just use a dull putty knife to scrape carbon off, but spraying it with gasket remover first softens it up to come off easy.
#15 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted November 05, 2012 - 08:21 PM
I used a can of carb cleaner to soften the crud, and a plastic putty knife, and small dremel with wire brush atachment. 2. be carefull drilling out that screw, but 3 should hold the stator fine. 3 that looks like the one I have.... If interested I would be willing to sell mine. truthfully I don't remember what it came off of, so some size measurements (Inside . Outside diameter) to make sure mine would work first. I count the same number of coils on both, so that is a plus.
