Basic How Install Or Remove Valve Springs And How To Reseat Or Lap Valves On A Small Engine
2 replies to this topic
#1 Delmar OFFLINE
Delmar
  • 2,433 Thanks
  • 2,480 posts
Posted October 28, 2012 - 07:24 AM
This is some how to video about making an old motor run better. Valves tend to carbon up and or pit over time. One of the things I will do for and old tractor motor is to remove the head, clean up the carbon buildup from it, and to clean-reseat the valves.
I use the finish or fine valve grinding compound. I have also chucked up a rubber cup like the one in the video into a power drill motor to turn the valve. Remember to run the drill motor on SLOW if you do it this way.
  • sacsr and HDWildBill have said thanks
#2 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted October 28, 2012 - 07:51 AM
Just a little different for spring removal on those old bolens tecumseh hh series, end up making a compression tool from an old set of training wheels,
Got an over head spring compression tool from princes auto, see if that works better
  • Delmar said thank you
#3 Delmar OFFLINE
Delmar
  • 2,433 Thanks
  • 2,480 posts
Posted October 28, 2012 - 08:08 AM
Have you a picture of the tool you made that you could add to your post Jehtro? I could only find video of the tool for the briggs.
