Flipping The Drive Belt?
6 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 28, 2012 - 01:06 AM
I am thinking of repowering the 1990 Craftsman GT18 I just brought home with a 13 HP Predator engine until I can determine if the the old Briggs opposed twin will be alright. I know those are driven off the front of the Briggs twin, but I need to run it off the back of the Predator engine. The drive belt does a fold to get under the tractor and then twists to vertical onto the transaxle. Does anyone believe I will have any ill effects to flipping the belt on the transaxle the other way (twist other direction) to be able to drive the the opposite way?
#2 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted October 28, 2012 - 01:57 AM
You might have a rub issue. I have done it a few times on Craftsman II's by accident. That will mess you up. testing out a new belt, put it in 3rd and let out the clutch and start going backwards.
  • wvbuzzmaster said thank you
#3 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted October 28, 2012 - 06:58 AM
Can't say I've ever tried it but I would imagine rat88 is right, I brought up pics of it and I believe there will be a rubbing issue. Good luck to ya
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 28, 2012 - 01:53 PM
Any other opinions?
The opinions I am getting are good, just not sure what I want to do. I need to go look at my other one rear quick I guess. But meanwhile, I like to hear other opinions as well.
#5 KennyP OFFLINE
  • 38,195 Thanks
  • 45,842 posts
Posted October 30, 2012 - 07:44 AM
I haven't had a chance to look over how the belt runs, so can't say if it can be flipped. The GTV was easy to do, but this is different.
#6 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted October 30, 2012 - 08:22 AM
Any other opinions?
have you looked in to a hub for flywheel side drive? Not sure if the aluminum flywheel would handle it, but it might be an option.
If I remember right, my old walker zero turn had a kohler engine with flywheel side drive and no "PTO" shaft, and I'm pretty sure it had an aluminum flywheel. Not 100% sure on that. I still have a parts engine laying around , I can check it tonight
Edited by rat88, October 30, 2012 - 08:23 AM.
#7 wvbuzzmaster ONLINE
  • 4,716 Thanks
Posted October 30, 2012 - 03:10 PM
Have yet to look at the engine but it has recoil on it, Mabey I will look at a parts breakdown.
