212 Needs Help
10 replies to this topic
#1 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted October 27, 2012 - 07:31 PM
Purchased a John Deere 212 at a auction today. It runs well and came with a snowblower. The problem is that it wants to jump out of gear. The variator does not seem to work either. I do have a 1969 112 that I could use for parts if they interchange. Any help would be great.
#2 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,494 posts
Posted October 27, 2012 - 07:44 PM
Most likely the detent ball springs. Shift forks are also problematic. Either way you need to open it up. If the 112 transaxle is good it is a direct swap other than a few machine specific bolt-on pieces. The 110/112/200 series tractors all use the same Peerless 2300 transaxle. You can download a pdf manual from Tecumseh. I opened one up but decided to swap in another instead of repairing the broken one.
Edited by Trav1s, October 27, 2012 - 07:45 PM.
  • A.C.T. said thank you
#3 mtoney OFFLINE
mtoney
  • 824 Thanks
  • 685 posts
Posted October 27, 2012 - 08:03 PM
I agree, swap in a good transmission if you have one. Quicker and many time cheaper. Variator might just be stuck from sitting unused for so long. Shoot some penetrating oil on the pivot points, Once you get the rear end swapped or repaired, some good use might free up the variable speed system. I just bought a 214 today myself. Not my first 200 series I have owned and defiantly not the first I have worked on. We saw many of them come thru the dealership where I used to work as a mechanic. Trying to find the $$ to open my own shop now. Mike
#4 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,494 posts
Posted October 27, 2012 - 08:09 PM
Some spray graphite from the local Napa helped the variator on the 110.
#5 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,494 posts
Posted October 27, 2012 - 08:31 PM
TECUMSEH - Small Engine Suppliers - Your online source for ...
  • Texas Deere and Horse and A.C.T. have said thanks
#6 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted October 28, 2012 - 06:58 PM
the service manual is on this web site in the manuals section
http://gardentractor...icans-handbook/
the transaxles are easy to work - it takes me under 2 hour to remove the transaxle, fix it and back in the garden tractor
deere has the spring and balls - to fix both shifter forks for around $10 plus you should get the gasket for the case
and 2 quarts on 85w-90 or 85w-140 oil for the transaxle
#7 sendmorebrains OFFLINE
sendmorebrains
  • 2 posts
Posted October 19, 2013 - 12:01 PM
I recently bought a snow blower for my 85' J.D. 212 w/hydraulic deck lift. Everything bolted up great but the snow blower would not raise. Don't know if hydraulic unit is not strong enough or adjustments need to be made in lift link or deck height knob. This is a model #75 blower. Does anyone have any suggestions or an owners manual. Thanks.
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,006 Thanks
  • 5,977 posts
Posted October 19, 2013 - 03:49 PM
Hopefully the variator trouble is the linkage..  The center sliding hub wears and sticks on the shaft and it won't move back and forth thus shifting the front to back belt speed.  (where your 'variator' action is happening)  One belt climbs up while the other sinks down is the trick..  They are sure nice when they work but I've heard they aren't fun to replace..  (& pricey too!  At LEAST $200 for parts)
Good luck with the lubing..
Edited by WNYTractorTinkerer, October 19, 2013 - 03:50 PM.
#9 1971Deere OFFLINE
1971Deere
  • 48 Thanks
  • 66 posts
Posted October 19, 2013 - 04:00 PM
Not familiar with that model #. I have a model 37a snowblower for my 214. The hydraulic lift handles it with ease.
  • sendmorebrains said thank you
#10 sendmorebrains OFFLINE
sendmorebrains
  • 2 posts
Posted October 19, 2013 - 04:26 PM
# 37 preceded #37a It has a different pulley configuration. Will try screwing out eye of lift link to max.
#11 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted October 20, 2013 - 08:29 PM
you might look a the front lift rod - and see if you can adjust it
and check how it is attach
the deck height nob is only for the deck
it had no affect for the front and rear lift
