Bolens Gt2000 Diesel Conversion Started
77 replies to this topic
#16 mjodrey OFFLINE
Posted October 28, 2012 - 04:46 AM
Chris,great job on the stub shaft. :thumbs:
  • Cvans said thank you
#17 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted October 28, 2012 - 06:13 AM
Very nice documentation of the project Chris. I'm sure that will be a very sweet diesel GT when you are done.
#18 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted October 28, 2012 - 11:10 AM
The next time I get drug along to the in-law's in-laws out in Watertown, I'm sneaking out to your place. Keep those pics a-comin'.
#19 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 28, 2012 - 06:24 PM
Posted Today, 11:10 AM
Your sure welcome. Let us know when your in the area and we will leave the light on. :D
#20 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 29, 2012 - 09:28 PM
Today was the day to tackle the PTO adapter. The first photo shows the serpentine pulley that is bolted to the flywheel. Didn't really want to damage it in case I needed to drive something off of it in the future but I did what to install an 1 1/4" shaft to run the PTO with.
First thing was to mount the pulley in the lathe and true up the center bore of the pulley.
After that it was time to machine out another flange with the same OD of the pulley and a shoulder to fit the ID of the pulley. Then bore the flange to a press fit and weld the flange to the shaft. Back to the lathe to true everything up.
The shoulder on the flange is only .050 but is snug enough to support the weight of the pulley. This will keep everything on center with the crankshaft and also in alignment when drilling the holes to mount the flange
Next the 6 holes where laid out and then drilled and tapped. Then it's back to the back shop and see how things go together.
From the looks of the next photo it appears that the the tractors PTO pulley and the flywheel shaft pulley are going to line up pretty nicely. The engine is very close to it's final position so I think things will work out OK. The shafts length will be reduced and a key-way cut into the shaft when the pulley is installed.
Here you can see the engine with the hydro shaft and the flywheel pulley shaft installed. Hopefully tomorrow I can make some headway on the motor mounts. With any luck the mounts will be here tomorrow. McMaster-Carr is pretty fast about getting things shipped.
  • olcowhand and twostep have said thanks
#21 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 30, 2012 - 08:31 PM
Was able to fabricate the engine mounts today. Hopefully the hoist will no longer be needed. Unfortunately the camera was up at the house so I didn't do a very good job of taking pictures today. After painting the parts black and assembling them they didn't photograph well so I will try and give a brief description of what took place today.
The mount attached to the engine block is a 2" x 3" x 1/4" angle iron with the 3" side against the block. I took another length (18") of this same angle iron and ran it along the inside of the frame with the 3" side against the frame. These will be attached there with 3/8" self threading bolts. To get the height needed for the oil pan to clear everything I needed at least 1 1/2 " of clearance between the two 2" legs of the angle iron. Mounting the rubber iso mounts on the two inch leg of the frame angle iron and using a 1" square tube top of the mount to set the engine on gave me an 1 3/4" clearance. A 1" x 1 1/2" laid flat would have worked better but I didn't have that on hand. Tomorrow I will finish bolting the angles to the frame rails and start planning the radiator installation.
Here you can see how things are starting to line up. The upper pulley is just setting on the shaft with no hub. The crankshaft actually came out lower than the original Kohler. I'm going to need shorter belts.
  • olcowhand, KennyP and twostep have said thanks
#22 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted October 30, 2012 - 08:38 PM
I'm envious of your shop time Chris! Very nice work you're doing my friend!
#23 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 30, 2012 - 08:49 PM
Daniel this free time was a looooong time in coming. Now I'm enjoying it so much and hope all here can someday experience the same thing.
#24 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted October 30, 2012 - 08:57 PM
How's the abscess doing?
#25 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 30, 2012 - 09:21 PM
Better but I'm going to be glad when I can get in on Thursday and get it looked at. Seems to be worse in the evenings and mornings. For 6 hours on Sunday afternoon the pain went completely away and I slept like a log. My wife bless her heart just let me sleep and it felt wonderful. Now it's getting sensitive to cold so I have to drink warm water. :mad2:
#26 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted October 30, 2012 - 10:04 PM
Chris, Your work is impressive to say the least. I hadn't thought about using ISO mounts on mine, but am going to now. Hope the tooth continues to get better.
#27 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 30, 2012 - 10:19 PM
Brian if you decide to use these mounts make sure you purchase them with a high enough rating. I purchased mine from McMaster Carr and they are rated at 370 lbs each. This sounds excessive but it is not. They have to not only support the weight of the engine but must absorb the engines power pulses and torque but also any sudden loads applied to the tractor. I installed ones rated for lighter loads on my other Bolens conversion and replaced then with these.
Good luck with your project.
  • Texas Deere and Horse and IamSherwood have said thanks
#28 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted October 30, 2012 - 10:25 PM
Thanks Chris, I will go with these. I use McMaster-Carr at work, great supplier.
#29 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted October 31, 2012 - 05:28 PM
Finished bolting the frame rails to the frame and placed the radiator were I'd like to see it go. Then replaced the hood and everything fits.
Looks to be plenty of clearance between the engine and the underside of the hood for the engine and radiator. I am going to have to remove the old baffle. I'm really happy that I'm not going to have to modify the hood on this project.
Quit early today as the weather was beautiful. Took the plane up and enjoyed the afternoon.
#30 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted October 31, 2012 - 08:52 PM
Did the electric fan come with the package, or was it scrounged up somewhere else? Pretty slim set up.
