Great Home Made Penetrating Oil
44 replies to this topic
#16 whst400 OFFLINE
whst400
  • 25 Thanks
  • 29 posts
Posted December 09, 2012 - 10:29 PM
Makes sense, the acetone offgasses quickly, and cools the part it is on. The surrounding metals shrink, thus letting the relatively thin oil in.
I have used it for a few years , and can tell ya it works well, even though the arnmhair theorists are the only one's to prove it LOL
There are only two ways that evporating acetone (or any other liquid) will cool the metal. One is if the acetone is compressed and evaporates when uncompressed, much like coolant in an air conditioning system. The other way is if the metal is heated above ambiant temperature. In this case the evaporation of the acetone isn't really what is cooling the metal, rather the acetone is absorbing the heat, much like quinching hot metal in a bucket of water. Some of the acetone may evaporate during this process if it is heated enough.
You may be thinking about how evaporating perspiration cools your body. It does indeed cool your body IF the ambient temperature is below your body temperature.
The reason this stuff works is that the acetone lowers the surface tension of the atf allowing it to work it's way into very tight spaces. The acetone then evporates and leaves the lubricating properties of the atf in place.
Edited by whst400, December 09, 2012 - 10:30 PM.
#17 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 09, 2012 - 10:36 PM
Yes , I omitted the part about heating metals to well above ambient temp, sorry about that . Similar quenching can be had with spraying water on a hot part, but with no added lubrocity... And good point about lowering the viscosity with the acetone as well. Thanks :-)
#18 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 10, 2012 - 03:58 PM
I used to use Kroil, but have went to using Marvel Mystery Oil and have never looked back.
Started using Kroil to clean my target rifle, but a friend was using MMO & Benchrest 9 mixed. He found that it would not change point of impact first round out of a clean barrel. I tried it and he was right. So have been using the mix in my rifle and straight MMO in the shop. It is much less expensive than the Kroil and available anywhere(not the case with Kroil).
Edited by JD DANNELS, December 10, 2012 - 03:59 PM.
  • marlboro180 said thank you
#19 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 10, 2012 - 04:51 PM
Very interesting, and sound like a good mix for sure.
#20 Cvans ONLINE
  • 6,630 Thanks
  • 6,123 posts
Posted December 10, 2012 - 05:26 PM
Funny you mention the Marvel mystery oil. If I can't lay my hands on the normal penetrating oil I will use the Marvel air tool oil and the results have been favorable. So that's an option also.
#21 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted December 10, 2012 - 05:36 PM
The tines on my Cub Cadet #1 tiller are a good candidate for this. One side came off of the tiller shaft very easily, but the other side.... no go, so far. They appear to have grown onto the shaft. I've heated and soaked with PB Blaster several time to no avail. I'm going to give the ATF/acteone mix a try, maybe the Marvel Mystery Oil.
#22 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,281 Thanks
  • 9,771 posts
Posted December 10, 2012 - 08:20 PM
That will be a diffinitive test. Let us know how it works, okay?
#23 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted December 10, 2012 - 08:42 PM
Will do! I hope it's good news!!
#24 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 10, 2012 - 08:45 PM
If not, just turn the Blue Tip Wrench up a notch . :rolling:
#25 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted December 11, 2012 - 10:09 PM
So what would be in ATF that would be better than making the mix with 20wt motor oil for example? I'm not too familiar with the ingredients in ATF.
And since I've only got MEK at the moment, that should also replace acetone fairly well? (Wifey won't give up ANY of her nail polish remover!:D)
#26 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 11, 2012 - 10:15 PM
Never tried it myself Harold, but as ya know, I'll give anything a whirl.
Hey, watch this! Hold my beer! LOL
Metyl Ethyl Keytone is nasty suff, so it sure might work ....
#27 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted December 12, 2012 - 05:10 AM
MEK is highly flammable, even just the fumes in a dry rag can ignite fairly easily. I don't know what is in the acetone, but when it's put on a rusty bolt (w/ATF) I can see tiny bubbles at work. I have used the mix with good results many times.
  • Sawdust said thank you
#28 LarryB OFFLINE
LarryB
  • 16 Thanks
  • 14 posts
Posted February 26, 2013 - 10:32 AM
As far as a handy container for dispensing the HMP oil.  I use a ketchup or mustard bottle that I got at Goodwill for little $.  :thumbs:   Its large enough to hold an ample supply for many projects , has a handy sized nozzle to direct it rite on the target object and it has its own little lid that is connected to it so you don't have to worry about misplacing it /forgetting where you put it.  Just replace the lid after use keeps the solution from evaporating.  Just shake it before each squirt.  :wave:
  • olcowhand and KennyP have said thanks
#29 HDWildBill OFFLINE
  • 8,975 Thanks
Posted February 26, 2013 - 11:10 AM
LarryB welcome to GTTalk, Please drop by the member introduction forum and let us know a little bit about about ya.  (a little secret around here the guys love pictures)  :thumbs:
#30 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted February 26, 2013 - 08:58 PM
I've found that melting a candle into the threads is great at loosening rusted bolts.
  • tractorgarden said thank you
