Great Home Made Penetrating Oil
44 replies to this topic
#1 york0060 OFFLINE
york0060
  • 310 Thanks
  • 146 posts
Posted October 26, 2012 - 04:01 PM
I saw this artical about removing rusty bolts: Using nuts and bolts that were "scientifically rusted" to a uniform degree by soaking in salt water, they then tested the break-out torque required to loosen the nuts. They treated the nuts with a variety of penetrants and measured the torque to loosen them.
Results:
Nothing: 516 lbs
WD-40: 238 lbs
PB Blaster: 214 lbs
Liquid Wrench: 127 lbs
Kano Kroil: 106 lbs
(ATF)/Acetone mix (50/50): 50 lbs.
The "shop Brew" of 50% automatic transmission fluid and 50% acetone seems to beat out the others.
Just wanted to pass this on!
  • MH81, Texas Deere and Horse, akretowicz and 10 others have said thanks
#2 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted October 26, 2012 - 04:06 PM
Hey...gotta stick with what works...necessity is the mother of all inventions....
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 26, 2012 - 04:14 PM
Since acetone evaporates very fast, any suggestions for how to keep it from evaporating out of the mix?
Mike
#4 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted October 26, 2012 - 04:50 PM
Put it in a bottle with a lid. We have gone through all this in an earlier thread. I've been using the 50/50 mix for some time with very good results.
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 26, 2012 - 05:55 PM
HMMM, since I have an spare small 3 in 1 oil bottle w/ the pull out plastic tube it would probably work good to keep it in.
Mike
#6 Guest_gravely-power_*
  • Guests
Posted October 26, 2012 - 06:00 PM
I have been using that formula for several years. I thought everyone new about it by now. It WORKS!
#7 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 26, 2012 - 06:01 PM
Is that not the same stuff that DanO calls "Pony Piss " in his videos?
#8 Guest_gravely-power_*
  • Guests
Posted October 26, 2012 - 06:03 PM
I don't know about that. I learned about it from an old mechanic years ago.
#9 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted October 26, 2012 - 06:26 PM
I read about this here when I first found this place. I mixed up a little to try and it seems to work pretty well.
I label mine, "RUST BUST."
#10 KennyP OFFLINE
  • 38,329 Thanks
  • 45,913 posts
Posted October 26, 2012 - 11:01 PM
Mike
I have something similar, small bottles with pull out spouts and little caps for the end. Just have to shake it good before you use it. One bottle is even labeled 'Rust Buster'.
#11 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted October 27, 2012 - 12:57 AM
Makes sense, the acetone offgasses quickly, and cools the part it is on. The surrounding metals shrink, thus letting the relatively thin oil in.
I have used it for a few years , and can tell ya it works well, even though the arnmhair theorists are the only one's to prove it LOL
Edited by marlboro180, October 27, 2012 - 12:58 AM.
#12 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted October 27, 2012 - 01:04 AM
When I use it on a really rusty bolt, I will usually let it 'work' for quite a bit. Sometimes, I'll put this on and wait til the next day to try to loosen the bolt. If it turns just a little, I'll put a bit more on. They usually come right off. I think I have only broken 2 or 3 of the real rusty ones off using this.
  • Sawdust said thank you
#13 mjodrey OFFLINE
Posted October 27, 2012 - 05:05 AM
I do like that ATF/ Acetone mix,it seems to work good.
#14 JRJ ONLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 09, 2012 - 03:51 PM
I have also just started hearing from different fellows about the mix, sound good to me and I like the small bottle with the long pull out spout, but you have to remember to place the cap back on or you loose the acetone. I remember using the small bottle when I was doing A/C work, a very handy little bottle.
Dick
Edited by JRJ, December 09, 2012 - 03:52 PM.
#15 Cvans OFFLINE
  • 6,648 Thanks
  • 6,128 posts
Posted December 09, 2012 - 04:12 PM
I use to use Kroil for many years with excellent results. Then I read about the transoil and acetone but was concerned about the evaporation of the acetone. I have noticed over the years that it takes a very little diesel spill for the stuff to creep everywhere. Tried mixing diesel 50/50 with old Auto transmission oil and that seems to work OK. Takes a little longer to penetrate than kroil but so far the results have been favorable.
