My $30 Gt 18
129 replies to this topic
#1 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted October 26, 2012 - 07:39 AM
Thought I would go ahead and start a thread on this. Hopefully, I can do a few things to it this weekend. Not sure what, as yet. I know the engine and transaxle need to come out. I may dig out the parts tractor to get ready for the transaxle swap. I need to get the clutch spring out of it for mybigwarwagon anyway. May be a month before I can get the engine swapped. Here's a few pics for those interested.
I will pull the mower deck to see what all it needs. Plus I can see what shape the lift is in. Plus I can see what differences there are between this deck and the green one I have.
I want to see what's up with that right front wheel too.
#2 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted October 26, 2012 - 08:05 AM
Kenny, that
I think something is bent! :smilewink: Gonna make a good tractor when you get done. So it's a belt to the trans? If so, then was it supposed to have twin belts to the trans?
#3 mjodrey OFFLINE
  • 2,356 Thanks
Posted October 26, 2012 - 08:06 AM
Good looking ags on it.
#4 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted October 26, 2012 - 08:13 AM
Kenny, that
Single belt to the trans, Daniel. That Hi/Lo transaxle is nice though! Could be a number of things on the wheel. I find out soon enough.
Maynard, the Ag's go on the Ford. This will have the turfs off the Ford, 23 x 10.50's. Ag's will be filled with WW fluid.
#5 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted October 26, 2012 - 08:19 AM
That's a smallish looking belt to handle what that thing can pull!
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 26, 2012 - 08:22 AM
I've given more for less. Looks like you did well.
Sent from my HTC One X
#7 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted October 26, 2012 - 08:28 AM
Great price! Lots of potential there and plenty to keep you busy this winter.
#8 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
It's 1/2" wide, I think. It will be given a close look when I pull it. I will need to check all the idlers under there too.
#9 Cvans OFFLINE
  • 6,668 Thanks
  • 6,134 posts
Posted October 26, 2012 - 09:08 AM
If set up right a belt will pull a lot more than some will give credit for. My Lister Wheel Horse conversion was one belt and it destroyed the trans-axle without slipping. The next one will be driven the same way. My CC129 runs a skinny belt around two 90 deg. turns and the full length of the tractor to to drive the tiller. That tiller will push the whole tractor without slipping. Been doing it for two years and still looks good.
If I remember correctly my Craftsman GT18 is shaft drive with high and low range. They must have made a bunch of different versions of this thing?
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 26, 2012 - 09:51 AM
Kenny, that's a good looking old Sears. Who made the "Craftsman" engine on it?
#11 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted October 26, 2012 - 11:52 AM
Wow those ag's alone are worth more than $30....great steal!!!
#12 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted October 26, 2012 - 12:31 PM
Oh that I know. My 620 Allis has twin 1/2" belts for the ground drive and they do not slip. But it needs twin belts, as she's a big tractor. My Bush Hog JBI that I put a TJD twin Wisconsin....I use twin 3/8" belts to drive the rear pto. I run a 53" tiller off it, and absolutely no belt slip.
#13 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 26, 2012 - 01:09 PM
I have zero belt slip on my Caterpillar when I leave it in low range. Single belt with big tires, craftsman just like Kenny's.
#14 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted October 26, 2012 - 04:22 PM
It's a B&S 18 HP, Brian. Tomorrow, I get to play with it! WooHoo!
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 26, 2012 - 04:29 PM
Good luck Kenny, I may be pulling mine's Briggs tomorrow... in favor of a 13 Hp Honda clone I have sitting around (will require belt flip). I hope you can make headway on yours and can report high success rates.
