Bolens QT17 bucking
5 replies to this topic
#1 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted August 11, 2010 - 07:37 AM
Good Day,
I have noticed that there are a few posts on the net concerning bucking or jerking hydro on Bolens QT's and similar. Well, now I have the same issue....violent bucking at just about any speed other than full. I have tried lifting the wheels and running the tractor backwards and forwards to remove air but that helped slightly. I also changed the fluid and filter. Any suggestions?
Regards,
#2 Bolens 1000 ONLINE
  • 15,555 Thanks
  • 18,319 posts
Posted August 11, 2010 - 08:15 PM
Sorry,
I'm not too familiar with the hydro's....
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 11, 2010 - 08:34 PM
I think you are on the right path (air in the system).
Does the fluid get foamy? If not we may have to look elsewhere.
#4 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted August 12, 2010 - 07:19 AM
Hi ducky,
Thanks for the response. No foam. I am trying to think of where it could be sucking air from. Bad check valve or seal? Nothing is leaking. Where would you start troubleshooting ducky?
Thanks
#5 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 13, 2010 - 02:25 PM
Is it a Sunstrand Hydro?
If so Here is a link to the service manual.
QSeries-servicemanual.pdf - Manuals - Garden Tractor Talk
Use these in most Masseys as well.
Never had this symptom before.
I would take a close look at the linkage and be sure it is not loose or sloppy. I think the swash plates could move at will if not held in place.
I say this because it will go away at full speed and you linkage would be able hold the swash plate at full travel.
Let me know.
#6 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 18, 2011 - 01:14 PM
Out of the four Bolens I had/have it seems to be always air. It is important to note that just raisning the tires and running the drive train a few times back and fourth will not remove all the air first time. I had to repaet the procedure every day for about a week and be sure you use the lift too. It was amazing how much was in there. Be persistent and it will come around.
