* * * * - 1 votes
Front End Loader - The Project Is Started.
162 replies to this topic
#121 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted July 03, 2013 - 08:29 AM
No. I only use a metal band saw, a grinding machine with cutting dish and hand file.
   :worshippy1:   Wow, even greater applause for your work!
  • Per said thank you
#122 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted July 03, 2013 - 08:31 AM
My pump on my Massey with FEL was off a Case 446 and not designed for  real side load either, but I run a standard pulley directly on the pump shaft and it's been working for years.  I run a 5/8" wide belt but do not have it tight at all, just half snug.  Doesn't slip, and not a high side load.
  • Alc, twostep and Per have said thanks
#123 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 03, 2013 - 03:42 PM
Once again everything looks awesome Per! :thumbs: Do you have a picture of the Grinding machine with cutting disk? What ever it is you have done a great job cutting out all those pieces for this project! :worshippy1: Also you must have a lot of files :D
Hi Chris
My grinding machine is not very special at all.
I use the very thin cutting disc a lot. Iron becomes like butter. They are only 1 mm thick. The last picture show a thin and a normal cutting disc.
  • Alc, chris m and boyscout862 have said thanks
#124 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 03, 2013 - 04:17 PM
Excellent craftsmanship!! Especially considering the amount of handwork involved. A dying art, I'm afraid.  I congratulate you on your work... I don't know if you've been asked, but do you do work in metal fabrication or machine shop for your regular job?
Smitty
#125 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 03, 2013 - 04:28 PM
Like the rest of the build... VERY professional. Nice to see quality work without using high dollar equipment.
One question; how do you know tha thte pump isn't intended for side loading? Or is it standard for them NOT to be designed for sideloading. I ask because now I'm in the design phase and the pump I bought does not specify what type of drive should be used. Thanks!
Yeah from where do I know that.
I can't say. I think I have learned it, when I was young and beautiful (now I am only beautiful   :bigrofl: ) during my school, but I know that a hydraulic pump, which is designed for sideload has bearing built in. The bearings are often needle bearings.
As far as I know it is standard NOT to be designed for sideload.
  • Texas Deere and Horse, boyscout862 and twostep have said thanks
#126 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 03, 2013 - 04:36 PM
Smitty
I am a skilled machinist, but that is now over 35 years ago.
I have been engineer for over 30 years and today I am sailing on a ferry as chief engineer.
Edited by Per, July 03, 2013 - 04:42 PM.
  • Texas Deere and Horse, chris m and boyscout862 have said thanks
#127 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 03, 2013 - 09:51 PM
Well, your experience and talents certainly show in your work.
Smitty
#128 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 03, 2013 - 10:30 PM
Hi Chris
That is (like Utah Smitty said) true Craftsmanship! When you said a grinding machine with a cutting disk, I was thinking maybe you had a Vertical or Horizontal Milling machine. I never imagined you would say it was an angle grinder!! Great job! :worshippy1: :thumbs:
#129 Texas Deere and Horse ONLINE
  • 14,811 Thanks
  • 15,501 posts
Posted July 03, 2013 - 11:12 PM
Per, I want to tell you how impressed I am with your level of skill on this project. :thumbs: The fact that you are doing all this with a Band Saw, Grinder, file and welder Absolutely    Amazing !! :worshippy1: :worshippy1: :worshippy1:
Thank you for sharing your build with us.
#130 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 04, 2013 - 07:53 AM
Yeah and a lathe and drill press.
Thank you all for all your nice words and your interest in my project.
:thank_you:
#131 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted July 04, 2013 - 11:47 AM
Yes, when he said he uses a metal band saw, angle grinder & file.... I was floored!
#132 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted July 05, 2013 - 04:43 PM
Today I have made a spring loaded v-belt tensioner. Maybe it is not necessary, but now it's done.
I have used the original v-belt tensioner.
This is the parts for the v-belt tensioner. The spring I have used was one I had lying around.
Modified v-belt tensioner.
This is how it looks. It is only mounted for demonstration.
I am still waiting for hydraulik pipes and hoses to arrive. I hope they will arrive next week.
Until then - have a nice week-end.
  • Alc, Texas Deere and Horse, chris m and 1 other said thanks
#133 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 05, 2013 - 05:32 PM
It has been a while since I have seen this thread, it has been escaping me! I am now caught up... wow! The tools you are using surprised me as well! I can say that the precision and symmetry of your work is amazing! Keep it up!
#134 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted August 02, 2013 - 03:29 AM
Hi again.
I ordered the hydraulic part for the FEL from a German company. The hydraulic parts are about 5 times cheaper in Germany than in Denmark. I paid the parts by Pay Pal, but the parts were never send from the company. I wrote back and forth with the company a lot but nothing happened. Then I got some help from jd. rasentrac and got all my money back.
THANK YOU VERY MUCH jd. rasentrac! :thank_you:
So I then ordered the hydraulic parts from another German company and here there where no problems. Finally I have received the hydraulic parts and I could continue with the project.
The hydraulic pump is here mounted in the front with suction and pressure hoses.
This is the oil suction hose going from the left tower to the pump. The hydraulic oil is sucked out through a strainer, which is mounted inside the Tower.
Pressure hose going from the pump to the manoeuvring valve block.
Here I have made a small bracket for mounting the return oil filter.
The pictures shows the oil return filter when it is mounted with a pipe going from the manoeuvring valve block to the return filter and a hose from the return oil filter to the right tower. Underneath the tractor there is going a cross over hose from the right tower to the left tower.
Here I am bending the hydraulic pipes, which will feed the cylinders with the hydraulic oil.
Here you see some of the hydraulic pipes on the boom.
The pictures shows a pipe from the one end of the cylinder to the other end. I use pipes instead of hoses, because I think it looks much nicer and elegant than hoses.
This is all for now. The project is getting closer and closer to the end.
  • olcowhand, Alc, Texas Deere and Horse and 4 others have said thanks
#135 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted August 02, 2013 - 05:43 AM
That is looking very good, Per! Excellent work! Glad you got your parts!
