Front End Loader - The Project Is Started.
162 replies to this topic
#151 Alc ONLINE
  • 5,996 Thanks
  • 6,923 posts
Posted August 06, 2013 - 05:43 AM
You sure set the bar high for us when we rout hydraulic hoses and lines :worshippy1:
  • Per said thank you
#152 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted August 08, 2013 - 02:30 PM
The Project is finished!
Hi to everyone.
The front end loader is finished.
Here are some pictures of the final result.
IMG_0743.JPG IMG_0744.JPG IMG_0745.JPG IMG_0746.JPG IMG_0747.JPG IMG_0748.JPG
I am quite satisfied with the final result.
It has been a long, expensive and interesting building process. It has for me been a pleasure to describe the building of the front end loader and I want to say to all of you:
Thank you for all your interest with the building!
Thank you for all your nice and friendly comments!
Thank you for being patient if it took a little long time before an update.
Thank you for being patient with my sometimes bad English.
:thank_you:
If I look back on my building there are 3 things, I should have done different:
  1. The cylinders have a 30 mm piston rod. This is not necessary. I should have used cylinders with 25 mm piston rods. (but maybe I will use some of them for a back hoe)
  2. The hydraulic oil pump is giving to much oil, when I run the engine at full rpm. I will mount a larger v-belt pulley on the hydraulic pump later.
  3. The cross over line for the hydraulic oil from one tower to the other has to be of a larger diameter. Now it is a 5/8” hose but I will make it at least ¾” (might not be necessary when the rpm of the oil pump will be reduced).
When I drive around on my tractor, I think the steering is a little too hard and that is even with an empty bucket. I will definitely mount a hydraulic steering.
My next projects will be:
Installing hydraulic steering.
Find and install a new muffler or make a vertical exhaust.
Building a micro back hoe. (if anyone have some drawings I am very interested)
I have made a little short video of my tractor with the front end loader and you will be able to see the monkey, who built the FEL.
Here is the video:
Enjoy it.
  • olcowhand, MH81, Alc and 9 others have said thanks
#153 KennyP ONLINE
  • 32,297 Thanks
  • 42,065 posts
Posted August 08, 2013 - 06:45 PM
That is truly an awesome tractor and loader. Thank you for the video  and taking us along for the build. You do excellent work!
#154 chaentjens OFFLINE
chaentjens
  • 100 Thanks
  • 122 posts
Posted August 08, 2013 - 07:07 PM
Awesome!
Sent from my SPH-L900 using Tapatalk 4
#155 chris m ONLINE
chris m
  • 3,311 Thanks
  • 4,044 posts
Posted August 08, 2013 - 07:30 PM
We should be thanking you Per! Great job and thanks for taking the time to document the build so we could follow along!
I will be looking forward to your next project!
Good luck working the little kinks out! It sounds like you have a great plan and will get them resolved soon.
And let me add one more thing. :worshippy1: :worshippy1: :worshippy1: :worshippy1: :worshippy1: :worshippy1: :worshippy1: :worshippy1: :worshippy1: :D
  • trowel and Per have said thanks
#156 TomLGT195 OFFLINE
TomLGT195
  • 3,086 Thanks
  • 2,384 posts
Posted August 08, 2013 - 07:31 PM
Ditto
#157 twostep ONLINE
twostep
    Rockstar
  • 1,933 Thanks
  • 2,514 posts
Posted August 08, 2013 - 09:39 PM
Beautiful work, amazing fit and finish. As I said before, I hope mine doesn't turn out as pretty because I would not want to get the pretty thing dirty!!
But when you do... We want video!!
#158 Cvans ONLINE
  • 5,232 Thanks
  • 5,442 posts
Posted August 08, 2013 - 10:00 PM
That is one nice looking loader tractor. Beautiful!
#159 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted August 09, 2013 - 06:34 PM
Looks great Per, looking forward to the futher upgrade updates and how it turns out.
#160 MH81 ONLINE
  • 28,941 Thanks
  • 29,290 posts
Posted August 09, 2013 - 06:40 PM
Beautiful. Thank you for allowing us to go on the trip with you.
#161 olcowhand ONLINE
  • 37,249 Thanks
  • 30,217 posts
Posted August 09, 2013 - 06:48 PM
:ditto:   Exactly, thank YOU!  That outfit looks SO nice!  Glad I left mine in rough & "natural farm" appearance.  If I prettied mine up like yours, I'd not wanna get cow poo on it!
  • KennyP, trowel and Per have said thanks
#162 UncleWillie ONLINE
  • 13,829 Thanks
  • 8,062 posts
Posted August 09, 2013 - 06:56 PM
Beautiful work. Too pretty to get dirty.
#163 twostep ONLINE
twostep
    Rockstar
  • 1,933 Thanks
  • 2,514 posts
Posted February 26, 2014 - 10:35 PM
Okay, where are the updated video's of this thing doing some work?!?!
