* * * * - 1 votes
Front End Loader - The Project Is Started.
162 replies to this topic
#1 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted October 23, 2012 - 03:18 AM
Hi all!
As I told you all in my first thread I wanted to build a FEL for my Gilson. This project is now started.
I ordered the plans for the FEL from this site http://www.p.f.engin....com/index.html and after about a week I had the plans in my hand. All the measurement in the plans is in inches, so I had to recalculate all of them into metric which we use in my country. Also the plans are made for a Cup Cadet GT, so I also have to do some modifications in order to fit the Gilson.
I have bought a hydraulic oil pump, the control valve and the cylinders.
The hydraulic oil pump delivers 22.8 liters at 1500 rpm. The control valve is a two block valve with open center and a maximum flow rate at 45 liters/min. I is my plan to use the V-belt PTO in front of the engine to drive the pump. This PTO has an electric clutch, so I can turn the pump on and off.
The cylinders I have bought are with 50 mm piston, 30 mm piston rod and they have a stroke of 400 mm.
I have over the last days built a very strong latter frame which will be bolted underneath the tractor. This is my own design and I think this is better and more solid than the frame of the tractor.
This piece off iron is a cross support bar (can I call it so) which will support the latter frame in the front. In the front of the tractor frame there is 2 holes with 3/8” thread. I use those 2 holes for bolting the latter frame to the tractor in the front and the support bar goes then underneath.
Pictures will come when I get it mounted.
Edited by Per, October 23, 2012 - 04:12 PM.
  • caseguy, Texas Deere and Horse, KennyP and 4 others have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted October 23, 2012 - 04:21 AM
From the looks of the loader sub frame you constructed, it will be as strong (or stronger) than the GT frame!
Keep us updated of your progress, and you know the drill....Pictures, pictures, pictures!
#3 mjodrey OFFLINE
Posted October 23, 2012 - 04:43 AM
You are off to a good start by the looks of things.
#4 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted October 23, 2012 - 05:16 AM
Cool frame you built there. We'll be watching for your updates. This sounds like a good project!
#5 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted October 23, 2012 - 05:40 AM
Your doing great work there ! Good luck with your loader , Al
#6 Cvans ONLINE
  • 6,640 Thanks
  • 6,126 posts
Posted October 23, 2012 - 07:09 AM
Looks like your on the right track. Nice work!
#7 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted October 23, 2012 - 07:14 AM
Looks very solid with nice welds. I especially like your shop too, looks very organized and neat :thumbs:
#8 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted October 23, 2012 - 08:14 AM
Wow! Thankyou for sharing. That is nice looking work, better than many professional shops. I would like to see more of the shop and some idea of the amount of time this is taking. The Bolens Club that I also belong to has backhoe plans at http://groups.yahoo....Back Hoe Plans/ . They may give you some other ideas. Best of luck to you.
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 23, 2012 - 08:15 AM
Keep up the good work! You obviously have the Fab skills to do this job. Your Sub Frame looks great.
By all means keep us up to date on this project. I have considered the PF Engineering plans, but did not have a machine to dedicate to loader duty so had not bought the plans. Actually watching someone do the project may push me into going ahead.
Once the Loader is done, are you going to build the back hoe from their plans?
Edited by JD DANNELS, October 23, 2012 - 08:16 AM.
#10 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted October 23, 2012 - 02:48 PM
Hi again!
It’s time for an update.
This afternoon I tried to mount the sub frame under the tractor.
This picture show the 2 3/8” mounting holes and the place where the cross support bar will be mounted (marked with red circles and square).
This picture also shows the 2 3/8” mounting holes and the place where the cross support bar will be mounted.
Here are the holes (marked with red circle) for mounting the sub frame at the rear end.
The front of the sub frame with the cross support bar mounted.
Cross support bar.
2 iron pieces with M10 thread. They go inside the frame at the rear end and the sub frame bolts will be screwed into these.
Left side of the rear end mount.
Right side of the rear end with all bolts.
Under the tractor from the front end towards the rear end.
Towards the front end.
Under the tractor towards the front.
Left side of the sub frame sticking out. Here will the tower be mounted.
Right side.
Tower mounts sticking out.
One tower put on loose.
This was all for now.
I will be glad to hear from you all if I should have done something wrong or if I could do something better.
Thanks.
Edited by Per, October 23, 2012 - 04:15 PM.
  • MH81, Texas Deere and Horse, KennyP and 2 others have said thanks
#11 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted October 23, 2012 - 02:56 PM
I have thought about building a back hoe also, but it has to wait until next year. All the hydraulic stuff were quite expensive and I don't even have the hydraulic fittings and hoses yet.
#12 Per OFFLINE
Per
  • 144 Thanks
  • 121 posts
Posted October 23, 2012 - 02:59 PM
Do you think I can join the Bolens Club without having a Bolens GT?
#13 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 23, 2012 - 03:55 PM
I don't have the time, money, tools, or a place to build one. I hope to in the future. I'll be following this thread. Great work so far.
Sent from my HTC One X
#14 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted October 23, 2012 - 05:37 PM
Seems you clearly know what your doing. Looks great.
#15 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted October 23, 2012 - 06:04 PM
:good_job: looks like your well on your way to a very useful build :thumbs:
