Tube Frame Snow Blade Rebuild With Power Angle
14 replies to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted October 22, 2012 - 07:01 PM
Ok here we go
winter is getting close and i just added Aux hydraulics to the h14 the snow plow i have is one of the first ones that they made with No trip release and no bracing i had it on in the winter and i Had a bit of a accident i was trying to be a swell guy (just wanted a tiddy bit of seat time) and i was plowing the side walk down to the park next thing i know i am on the hood and looking at the snow blade i bent the bottom all to heck also bent in a V (did alot of damage) so i straighten it and bubble gum weld it back together i have a newer plow id say late 70s so i am going to rebuild this one i will cut all the bent and wrecked mounts so i just have the round part and add 6" to it so its 48" and make a trip release change the angle from 45 to 70 for better snow rolling and scraping ability and make a new A frame with mounts for 2 2x10 hydraulic cylinders something like Steevo did on mtf if any one wants the old frame work let me know Also if you notice how its in the box of the truck its going to School for a project and should i just go 6 or should i go 10 wider ? i do believe i have plenty of tractor to push it let me know
Cheers
Tyler
#2 boyscout862 ONLINE
  • 15265 Thanks
  • 10024 posts
Posted October 23, 2012 - 10:26 AM
Good luck with it. I would like to see the results. I have a 1050, 850, 853 and an H14 none are running but I hope to get one running soon to put a plow on it. Unfortunately, firewood and family responsibilities take priority.
#3 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted October 24, 2012 - 09:15 PM
Did some more work today cut all the bent stuff of and straightened it i only had 2 1/2 inch wide strips opposed to 3 so its 1 inch shorter than i wanted i welded it up next i need to build the frame work and the pivot that might be 7/16 plate ! i am still trying to figure out if i should go with the 2 single action cylinders or the double
Cheers
Ty
#4 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted November 14, 2012 - 03:15 PM
welded Angle on the blade Made the pivot mount and bushing (the bushing WAS a PITA Princess auto did not have a 7/8 bore bushing so i made one on the Mill) made the A frame Today Tacked it up And received a Donation ... a New cylinder ! from a Bob-cat Tomorrow i should be making up the Side rails for the pivot for the trip release more to come ! And a Sneak peek on the Next project Let say its going to be something like 1256-D :P
Cheers
Ty
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted November 14, 2012 - 05:38 PM
Nice looking headway, can't wait to see the project in action.
#6 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted November 15, 2012 - 05:21 AM
I just read this for the first time, and was going to say use a DA cylinder when you asked, but then saw in your next post that you got one, and at the very best price :D :D :D
I know I'm "late to the party", but will this help? It's pic of the Large Frame 4 way blade.
Edited by OldBuzzard, November 15, 2012 - 05:22 AM.
#7 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted November 15, 2012 - 05:53 PM
hey i have a blade exactly like that except it says MONTGOMERY WARDS across the top :smilewink:
#8 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted December 06, 2012 - 10:24 PM
Some more work It was panted with a brush (not my idea ) im tempted once its home ! i might get it Sand blasted in the summer ! or dip it in the electrolysis tank ! All brackets are mad every thing is almost painted should be done and on the tractor by next weekend
Edited by 8tyman8, December 06, 2012 - 10:27 PM.
#9 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted December 07, 2012 - 01:22 AM
WOW that sounds painfil an i hope your alright and the bolens to// you will have her up and running again in no time. also did bolens make a power angle blade for a tube frame? if so thats pretty sweet i never heard of 1
#10 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted December 07, 2012 - 03:29 PM
Bolens (that i know of ) Did Not make a power angle blade For the Tube frame ! they did Not even put Aux hydraulics on there tube frames (it would have been a smart idea ) how ever at the same time frame john deere was putting out the 140s and 300s in H3 with 3 hydraulic circuits how ever the did have aux hydraulics 1886 and any thing over 1886 Has Aux hydraulic you can run Alot of aux hydraulics blades/ Snow-blower chute rotators/winches "ima going build one of them" / pumps and some times even Log splitters Loaders and back hoes !
#11 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted December 09, 2012 - 07:31 PM
ok gotch ya
#12 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted December 10, 2012 - 08:42 PM
got it home and together ! got lines made up and couldn't find my New Quick connects so had to steal some :l was going to try it but is a mud hole ! its got Alot of power angle drove up to a tree and hit the angle Yup shoved the tractor Backwards ! Now i need Snow it was a fun project ! now i just need to make the lift linkage and pivot pins !
#13 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted December 25, 2012 - 04:55 PM
#14 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted December 25, 2012 - 07:57 PM
instead of alll that work i would of git a (TF) blade an put a cylinder on it? or did you want a wider then 42in?
Edited by 1967bolens collector, December 25, 2012 - 07:59 PM.
#15 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted December 25, 2012 - 08:22 PM
The old blade was broken and i wanted it wider also it had no trip release the metal was Free the only thing that cost money was the cutter bar and blots
