Plans for a riding sulky
4 replies to this topic
#1 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted August 10, 2010 - 12:50 AM
Does anyone have a set of plans for a riding sulky. I plan on making several for a train for the kids.
#2 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted August 10, 2010 - 02:45 AM
To answer my own question I found this site that has everthing: www.freepatentsonline.com/6874796.html
#3 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted August 10, 2010 - 05:17 AM
That one they have shown in those drawings wouldn't provide much ground clearance. I would make a triangulated frame with either front wheels and tires or rear wheels and tires from about an 8hp size gt and then get a metal pan seat from TSC and put on it. I actually want to build one of our own for going to tractor shows. I may end up doing a bench seat type one or multiple sulkies (sp?)
#4 caseguy OFFLINE
  • 1,628 Thanks
Posted August 10, 2010 - 03:22 PM
I agree with you NUTNDUN. I think ground clearance would be an issue on anything but perfectly level ground. I found this pic online of a sulky for a David Bradley. I think this design would be better for a single rider.
This one is called a soft tail due to the suspension, but they made one that was rigid also. This is the best pic I could find of it though
#5 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 03, 2010 - 08:45 PM
whatever you build, add brakes to it, even if you don't need them for your particular machine,
they may be needed if the sulky is attached to a walk-behind without brakes.
a simple go-cart style, (paddles that rub the sulky wheels), will work.
(brake peddle on the tongue)
