I Need Help With Snowblower
7 replies to this topic
#1 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted October 20, 2012 - 05:29 PM
Hello;
I had just replaced the main impeller bearing on the 42" Ford two stage blower.
During this work, I had the three sets of chains soaking in 30 W motor oil for a few days. When I took the chains out of the oil to install the oil had rust in it.
So I put the chains on and s got a noise(sounds like the chains) but not sure if it's normal for one of these units. Also, before I replaced the bearing, the auger and the input shaft turned pretty quiet.
So, do I need chains or what do you think?
All the best
#2 Arti ONLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted October 20, 2012 - 07:02 PM
I had a noise that sounds like what you are describing.. It ended up being the bearing in the middle front of the blower.. This is actually a bushing type T shaped bearing setup It's on a 42 inch 2 stage Ford blower.
#3 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted October 20, 2012 - 07:35 PM
Arti;
Can you tell me what kind of a job that is to do, and can a man make or get that bushing?
all the best
#4 Arti ONLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted October 21, 2012 - 07:50 PM
Horvick, I took mine apart and cleaned it up , lubed it with gun grease, It appeared that when using the grease fitting that it was only lubing part of the bearings.
#5 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted October 22, 2012 - 04:48 PM
Hey Arti;
I took it apart as you said, and looked okay. I am wondering whether to replace the bushings, not sure as they look good to me.
there was a lot of grease inside when it first come apart.
The one chain had put rust in the can where it was soaking in oil . Probably need to replace it.
Any other ideas , please let me iknow.
All the best
#6 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted November 02, 2012 - 10:13 PM
Hey Horvik,,If it is the chain then try some of this stuff I have a pic of below,, I had some vib's from chain's an folks had told me they hear noise comeing frim chain's on different things I have had,, Put a good coat on an run it couple times an see if it smooth out for ya,, Really did for me,, Its Teflon Chain-Saver,, Just oil on chains don't really smooth them up much but this stuff works great,, I use it on my motorcycles an any chains,, Hope this helps ya out,,, Even helps keep water off the chain's an dirt,,
  • KennyP and Arti have said thanks
#7 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted November 07, 2012 - 07:01 PM
Hey;
I noticed that the driveshaft ahd wobble in it when the PTO was engaged.
So took it all out,a dn found that the end to the blower had about 1/8" slop in it. Goit news joint ordered and hopes this fixes the wobble. Shafts and all is straight.
#8 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted November 07, 2012 - 09:01 PM
Oh ok,, Cool,, Hope that takes care of it for ya,,
