Picked Up Mf12h
40 replies to this topic
#31 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted November 28, 2012 - 07:13 AM
Now there's 3 of them. LOL I bet they are nearly the same dimension wise. When Alan (or someone) gives the okay on the drawing, I'll make it a .pdf and upload to the MF Manuals/?. Would it be best to put it with the implements or in Misc.?
EDIT: I can do up a drawing for the 1032382M91, using the same height if you guys want.
#32 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 28, 2012 - 05:46 PM
Here's an earlier thread about the bracket.
http://gardentractor...age__hl__ mf630
#33 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted November 30, 2012 - 10:20 AM
2 different brackets were used, both did the same job.
I have a question about these. The one on the left has the 'guides' for the mast at the bottom. The other has them at the top. Would it be okay if they both were at the bottom?
#34 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted November 30, 2012 - 03:13 PM
If I were to make one it would be exactly as the original. But your drawing it.
#35 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted November 30, 2012 - 03:20 PM
I was just trying to figure out why. I have a drawing going as original, just the question popped into my head. It's nearly done, Just not sure of the height of the 1032382M91 (second one). So I made it to the same height as the first (13.5").
#36 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 30, 2012 - 05:45 PM
I don't think it really matters where the guides are, top or bottom, but if you want it original the make it the same as the Argo drawings.
I've had 3 if these dozer blades and none of them came with a bracket.
#37 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted November 30, 2012 - 05:51 PM
Thanks, Doug. I'll make it like the pic.
#38 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 30, 2012 - 06:02 PM
Will this bracket work for the MF 14/16 blade?
#39 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 30, 2012 - 07:08 PM
Not sure if the bolt holes line up.
MF14, 16 do not have the lift assist spring. The 10s and 12s don't really need it either blade can be raised without it.
MF530
Edited by DH1, November 30, 2012 - 07:29 PM.
#40 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted November 30, 2012 - 07:09 PM
I suppose it could work. But you would only need the bottom part with the two "prongs", the 530 blade has no assist spring. Also, I'm not sure if the width of the vertical stabilizer piece is the same as the MF12's blade.
#41 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted November 30, 2012 - 07:22 PM
MF14, 16 do not need the lift assist spring. The 10s and 12s don't really need it either blade can be raised without it.
MF530
That's a simple bracket there.
