Picked Up Mf12h
40 replies to this topic
#16 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 24, 2012 - 08:10 AM
I just use a couple of pieces of angle iron, all it does is stop the blade from going side to side. You do not need the lift assist spring.
#17 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted November 25, 2012 - 08:14 PM
OK, I got some pics of it tonight. Please let me know if you need any more info.
#18 KennyP ONLINE
  • 51017 Thanks
  • 52655 posts
Posted November 26, 2012 - 06:59 AM
Some of those measurements are a bit hard to read. How wide is the piece on the blade that this keeps centered? It looks like 2" channel? Can't make out the overall height. 13"? 14"?
#19 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted November 26, 2012 - 08:08 AM
Sorry about the illegibility, the overall hgt was 13.5" and the cutout is about 2.25". It's actually a little under by the looks, but I can double check on Wed nite..
Never thought to take calipers for thickness... :wallbanging:
#20 KennyP ONLINE
  • 51017 Thanks
  • 52655 posts
Posted November 26, 2012 - 08:51 AM
After looking back thru, I had a good guess on height. I figure it to be around 1/4" thick. The slot width I had guessed at 2-1/8", but that depends on the piece coming up off the blade.
#21 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted November 26, 2012 - 11:48 PM
Thanks for the pics, that should help a lot.
#22 KennyP ONLINE
  • 51017 Thanks
  • 52655 posts
Posted November 27, 2012 - 05:53 AM
I'm working on a drawing, but that issue called 'work' keeps getting in the way.
#23 KennyP ONLINE
  • 51017 Thanks
  • 52655 posts
Posted November 27, 2012 - 07:28 AM
I went ahead and have a couple drawings completed. If someone wants to name this part (or has a part # for it) I will make a .pdf to put it in the manuals section IF no issues are found in the drawings. Alan, if you could print out the dimensioned one and check against your piece, that would help.
#24 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted November 27, 2012 - 12:00 PM
Bracket - Stabilizer 1038929M1 This one came with the late production blades w/ no skid shoes.
#25 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 27, 2012 - 05:22 PM
2 different brackets were used, both did the same job.
#26 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted November 27, 2012 - 05:52 PM
I think the 2nd one is the "correct" one for my plow. But, like you say both do the same job. I think the 1st one would be easier to make.
#27 KennyP ONLINE
  • 51017 Thanks
  • 52655 posts
Posted November 27, 2012 - 05:56 PM
You mean I have to draw up another one, Doug? Get me some dimensions and I'll see what I can do.
So what I drew up is not a 1038929M1? Ya'll got me lost now!
#28 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted November 27, 2012 - 09:14 PM
What you drew up is 1038929M1. The correct one for my plow ( not that it really matters they all function the same) is in DH1's second picture. 1032382M91.
The style you drew up for us was used on late production blades, with one peice push tubes, and no skid shoes.
The other style was used with the late production blade WITH skid shoes.
There was also a third variant used on the early production blades with 2 peice push tubes, it was similar to #2 though.
#29 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 27, 2012 - 09:40 PM
Late model with skid plate
Late model with skid shoes, 1 piece main push tube
Early model with skid shoes, 2 piece main push tube
  • MH81, IamSherwood and KennyP have said thanks
#30 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted November 27, 2012 - 09:55 PM
Also I notice that the early model originally had only 1 hole in the rear bracket that attaches to the tractors rear hitch, this was made for the MF10 before the MF12 came out.
MF12Hydros had a longer frame, so they made the bracket with 2 holes in it so it can be used on both tractors, Vari-Drive and Hydra drive.
  • IamSherwood and KennyP have said thanks
