Breathing Difficulties?
9 replies to this topic
#1 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,423 Thanks
  • 8,679 posts
Posted October 20, 2012 - 11:56 AM
I have a Kohler K341 that I rebuilt, modifying it slightly; K361 cam and a shaved head. I am still rebuilding the tractor, but decided to start the engine and see how it runs. The tractor doesn't have a battery, yet. So, I jumped it from another tractor. Well, it barely would turn over unless I pulled the spark plug. Jeez, the head isn't milled that much.
So, I decided to use the truck to jump it and if the throttle was closed it would crank right over. If I opened the throttle, it just stopped. Does this sound like valve timing?
#2 Guest_gravely-power_*
  • Guests
Posted October 20, 2012 - 12:15 PM
Sounds more like a weak starter. You probably increased the compression to 10:1 or so. the stock starter does not have enough oomph. Ck Brian Miller's site for starters.
#3 MH81 OFFLINE
  • 29,524 Thanks
  • 29,576 posts
Posted October 20, 2012 - 12:40 PM
Could be a weak starter or bad connections via the jump. Steal a battery out of something else (I know, you were trying not to do that) and try it again. Direct connections always seem to have more punch.
#4 Cvans ONLINE
  • 5,546 Thanks
  • 5,614 posts
Posted October 20, 2012 - 03:09 PM
Check your point setting. If they are too wide you might be getting pre-ignition and kick back that is stalling the starter. Depending
on how much you shaved your head you might have to retard your timing.
#5 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted October 20, 2012 - 03:11 PM
Also double check your valve clearances. If too wide, the auto compression release can't function.
#6 DH1 OFFLINE
DH1
    Electric Tractors
  • 4,935 Thanks
  • 5,435 posts
Posted October 20, 2012 - 03:12 PM
Is the decompressor working?
#7 DH1 OFFLINE
DH1
    Electric Tractors
  • 4,935 Thanks
  • 5,435 posts
Posted October 20, 2012 - 03:13 PM
You beat me by 1 minute.
#8 olcowhand OFFLINE
  • 37,720 Thanks
  • 30,340 posts
Posted October 20, 2012 - 03:17 PM
Ya gotta be fast Doug! :smilewink:
#9 Guest_gravely-power_*
  • Guests
Posted October 20, 2012 - 03:21 PM
The spring on my ACR came off and it would not crank. However, with higher compression ratio I have found that Kohler starters do not work very well.
Edited by gravely-power, October 20, 2012 - 03:26 PM.
#10 LilysDad OFFLINE
LilysDad
  • 11,423 Thanks
  • 8,679 posts
Posted October 20, 2012 - 03:47 PM
I didn't shave it that much. I went by Miller's recommendations and the ratio is only a little better than 8:1. Any more than that and the valves would hit. I'll check the points and put a battery in it. If neccessary, I have another starter.
Edited by LilysDad, October 20, 2012 - 03:48 PM.
