Landscape Rake
5 replies to this topic
#1 icpik OFFLINE
icpik
  • 23 Thanks
  • 40 posts
Posted October 17, 2012 - 11:34 AM
I have a PK 2414 with fluid in the rear wheels and no additional weight in the front. I am looking to purchase a landscape rake. Available cat 0 rakes that will fit are either 4 or 5 foot in width. The outside of my rear tires are just over 4 feet wide. I would prefer a 5 foot rake which will allow an angle and still cover the rear wheel width, but I am not sure if the tractor will pull it. I plan to use the rake for minor road dressing and weed removal. Any suggestions?
Don Hayes
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted October 17, 2012 - 11:38 AM
You should have no problems. I use a 5 foot rear blade all the time without issue. Just make sure (if you happen to get a 5 footer that is cat. 1) that you can put cat. 0 pins on turned in. Otherwise it won't fit. If you do find a cat. 0 rake that is 5 foot, then you're fine.
Edited by David Brown, October 17, 2012 - 11:39 AM.
#3 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted October 17, 2012 - 06:54 PM
Jeff pretty well covered it. HERE is an active thread about pretty much the same thing.
I have a 4 footer CAT 0 and it works great, the tractor handles it with no problem but it does not cover my tracks when it is angled.
#4 olcowhand ONLINE
  • 41,035 Thanks
  • 31,384 posts
Posted October 17, 2012 - 06:56 PM
Don, I agree with the guys....no problem with the 5' rake at all!
#5 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted October 17, 2012 - 07:28 PM
Don't, however, try to use a 5 foot box blade. 4 foot is plenty for that.
#6 icpik OFFLINE
icpik
  • 23 Thanks
  • 40 posts
Posted October 18, 2012 - 06:59 AM
Thanks for the input. I'll keep looking for a 5 foot that can go cat 0 or cat 1. I have a larger tractor for box blade and any heavy rake work. The 5 footer won't cover the tires on the larger tractor, but I can go back and dress if needed.
Don
