John Deere 210
#1
OFFLINE
Posted October 16, 2012 - 05:18 PM
A guy that i work with said his dad is cleaning house and wanted to know if i was interested in it.He bought it with a bad transmission.He rebiult it and thats where it set.Hasn't run in a couple of years so i'm thinking battery and carb cleaning.He's bringing in pictures tommorrow.
#2
OFFLINE
Posted October 16, 2012 - 05:27 PM
- ckjakline said thank you
#3
OFFLINE
Edited by Trav1s, October 16, 2012 - 05:28 PM.
#4
OFFLINE
Posted October 16, 2012 - 05:34 PM
I've noticed that the prices are all over the place up here depending on the condition of the tractor and if any attachments are included. Haven't seen one sell since early summer when there were 3 200 series sell with in a couple of weeks. Asking prices were between 400 and 800 if memory serves. One thing to check out on them is the steering. If it's got a lot of slop in it you may have to spend a bit of $ to get it sorted out. Wheel bearings, tie rod ends, axle bushings, front spindles and other parts of the linkage tend to wear out over time. If you need to replace all of this stuff it will go over 100$ easy.
If the column needs rebuilt the kit is on back-order through Deere. My dealer got one from another dealer that had it in stock. The 4 tie-rod ends are $15 a piece. The rebuild kit plus the misc parts to rebuild the column at close to $50. Wheel Bearings are about $5 a piece. There is is $120 and that does not cover all the pieces.
Edited by Trav1s, October 16, 2012 - 07:13 PM.
#5
OFFLINE
Posted October 16, 2012 - 06:58 PM
#6
OFFLINE
Posted October 16, 2012 - 09:04 PM
I rebuild the kohler k241 motor - new piston, rings and rod
I serviced to whole tractor from front to back
others in the area complete running go for $400 to $900 - depends on if it is manual, electric or hydro lift just with a mower deck
if it does not start or have other problem they go for $100 to $250
- Trav1s and ckjakline have said thanks
#7
OFFLINE
Posted November 18, 2012 - 09:53 AM
#8
ONLINE
Posted November 18, 2012 - 10:16 AM
#9
OFFLINE
Posted February 11, 2013 - 11:31 AM
bought mine for $130..... was loaded onto trailer with fork lift, followed out of field by several cows----quite funny actually.
seller did say engine was 'tired', and used to die going uphill---
when i got it home, i discovered that carb was flooding really badly(hence dying going uphill, cuz gas flowed back into carb), so i took it apart and adjusted float, now it runs perfectly, starts exc., no oil burning etc.....
it is one of my favorite looking tractors--of any brand,,,,
yours looks in good shape---
- Texas Deere and Horse and ckjakline have said thanks
