Need A Bushing For Pto Clutch...
11 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted October 16, 2012 - 01:53 PM
I have seen posted on here somewhere that carries steel bushings to use on Crankshafts and PTO's. I have a replacement engine for one our 318's and it has 1 1/8" PTO shaft, the clutch is for the standard JD Onan 1 7/16" PTO. McMaster-Carr doesn't carry them, I thought they do. Give me a idea where to get them..
  • 14,800 Thanks
  • 15,495 posts
Posted October 16, 2012 - 02:27 PM
Small engine warehouse doesn't carry one..
#3 Grumpy ONLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted October 16, 2012 - 04:35 PM
How long dose it need to be? What size key? It should .250 Maybe I can whittle one out for you.
#4 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Haven't a clue, Brian! Hope some one has some info for you!
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 16, 2012 - 04:56 PM
Have you measured that shaft Brian? That seems like an odd size but then again I'm not familiar with the Onan engines.
#6 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 16, 2012 - 05:09 PM
Check with a local small engine shop. Then may have one in a 20 year draw. Which I could help you further.
  • 14,800 Thanks
  • 15,495 posts
Posted October 16, 2012 - 06:12 PM
Thanks Guys!! I am going to check with my local shops, and I can machine one myself. I thought I remembered someone posting about someplace that had these bushing on the shelf.
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 16, 2012 - 06:20 PM
About 2 AM it will hit you where you saw the posting. Happen's every time to me! :smilewink:
#9 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted October 16, 2012 - 06:46 PM
Brian on my 318 w/ replacement engine I used a bronze bushing that was the correct ID/OD just had to cut to length and cut out a spot for the key , that had to a be rectangle can't remember the size maybe 1/8 x 1/4 ? Got the bushing from a bearing place, Al
#10 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted October 16, 2012 - 07:56 PM
Al, How is the bushing holding up? Have you noticed any play from it mushrooming on the shaft? How many hours do you think it has on it?
#11 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted October 17, 2012 - 05:58 AM
The bushing held up fine , guessing about 5 years now , only a couple of hundred hours , If your worried about any play Loc-Tite makes sleeve retainer that fills gaps of a few thousandths or some other Loc-Tite's that would be as hard to get off if needed . Al
  • IamSherwood said thank you
#12 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted October 17, 2012 - 08:07 AM
I just went out and checked Big Bertha's Onan. It has the 1-7/16" crank in it. Yes it's odd, but was common with Onan, I believe.
