Cub Cadet Kohler Revving
9 replies to this topic
#1 SearsYellow OFFLINE
SearsYellow
    Mower Extraordinaire
  • 514 Thanks
  • 599 posts
Posted October 15, 2012 - 06:42 PM
This engine just started reving up and down. It just radomnly started while I was mowing. I put new gas in it and bought a new airfilter but that has not helped at all. I'm not sure what could be causing this. Would cleaning the carbon help?
Sent from my Kindle Fire using Tapatalk 2
#2 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2365 Thanks
  • 2496 posts
Posted October 15, 2012 - 08:16 PM
Could be a number of things but start with the basics
I would make sure the fuel is getting there- filter etc. Good luck
http://www.kohlereng..._1346_c_all.pdf
#3 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted October 15, 2012 - 08:19 PM
I just finished fixing a cub LT1050 with a Kohler. 2 things to check for: 1: there is a small hose coming off the fuel pump that goes to the left valve cover. Make sure it is in the hole of the valve cover. While I was cleaning and installing the carburetor I must have knocked the one I was working on. When I was testing it out I started getting some erratic behavior and one of them was surging. Next i would check for an air leak around the intake manifold.
#4 chuck Grumpy Aldridge OFFLINE
  • 1119 Thanks
  • 745 posts
Posted October 16, 2012 - 09:21 AM
I would look for dirt in the carb, but first I would check the governor adjustment.sometimes they slip.
#5 JDBrian OFFLINE
  • 9681 Thanks
  • 14162 posts
Posted October 16, 2012 - 10:34 AM
Make sure the governor linkage is in good shape, moving freely, no broken or loose springs etc. You could have a fuel delivery problem but if that all checks out check the spark, points gap etc. An engine with marginal ignition can give you some odd symptoms.
#6 Kyocum OFFLINE
Kyocum
  • 337 Thanks
  • 455 posts
Posted October 16, 2012 - 11:29 AM
I think before any accurate assessment can be made we should know what model engine we are dealing with. Just my thought on the matter.
#7 KennyP ONLINE
  • 52642 Thanks
  • 53133 posts
Posted October 16, 2012 - 04:43 PM
I agree. It's hard to diagnose over the internet if you don't know what the patient is!
#8 chuckt OFFLINE
chuckt
  • 14 Thanks
  • 21 posts
Posted February 26, 2014 - 12:11 PM
Hmm that's precisely what happened to ours also! And I believe it's the same model.
Sent from my SAMSUNG-SM-N900A using Tapatalk
  • A.C.T. said thank you
#9 chuckt OFFLINE
chuckt
  • 14 Thanks
  • 21 posts
Posted March 23, 2014 - 10:52 AM
Ours is being serviced (every other year, between times I do the oil and filter change) and I've asked to have the "hunting" fixed. I will try to post here what they tell me they find and the fix $$ I suppose😟
I ran it again before I took it in and with more (fresher?) gas in the tank a large part of the surging/hunting subsided.
Sent from my Samsung Note 3 using Tapatalk.
#10 chuckt OFFLINE
chuckt
  • 14 Thanks
  • 21 posts
Posted April 07, 2014 - 04:41 PM
Our CC 1046 is back, finally. The mechanic found nothing wrong at the carb. He did replace the fuel filter and fixed a slight oil leak (it was more unsightly than serious). Runs like a champ again so I'm guessing it was a combination of filter and something falling into the fuel probably when I topped up the tank?
