Can Kohler Cranks Be Interchanged Between Different Models?
kohler k341 k321 crankshaft
2 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted October 15, 2012 - 12:59 PM
I am rebuilding a Kohler K341 16 hp engine for my Ford LGT165. I have a copy of the Kohler Crankshaft reference, plus the parts manuals for all of the Kohler K series engine.
I see that the crankshaft in my engine is the same part number as some used in the 14 hp K321 engines--45 142 21.
Will these two crankshafts interchange? I have a chance to purchase a K321 crank in good condition for about the same cost as it would take to grind my K341 crank.
Thanks,
Steve
  • 14,800 Thanks
  • 15,495 posts
Posted October 15, 2012 - 01:32 PM
Form what I understand, you can use either crank in either motor, they are the same crank.
If you read thru this thread, the crankshafts were discussed at length.
http://gardentractor...-k341-troubles/
  • caseguy said thank you
#3 Guest_gravely-power_*
  • Guests
Posted October 15, 2012 - 01:50 PM
Thanks,
Steve
This will help you.
http://gardentractor...com/balance.htm
Also tagged with one or more of these keywords: kohler, k341, k321, crankshaft
