Why I Like Casters On My Welding Table
3 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 14, 2012 - 05:58 PM
I can get it out where I need it. It usually sits just the other side of the radial saw w/ the cutting grate against the wall. The mig sits over in front of the furnace and the chopsaw sits between the bench and furnace. All out of the way.
I spent part of today building frames for storage racks above the garage door. I have a sheet of OSB and 3- 8' 2x4's I set up on sawhorses for when I need a large work table. I made it a double decker so I can put the OSB and 2x4's on the lower deck and scraps of sheetrock, plywood etc. on the upper.
Mike
#2 KennyP ONLINE
  • 38,377 Thanks
  • 45,933 posts
Posted October 14, 2012 - 06:22 PM
That's real good IF you have something for the casters to roll on. I have just a small area (8' X 10"~) that is paved. The rest is dirt. See this thread:
http://gardentractor...s-tractor-port/
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 15, 2012 - 06:07 AM
Sorry, Kenny, I didn't know you were limited on solid floor space.
Mike
#4 KennyP ONLINE
  • 38,377 Thanks
  • 45,933 posts
Posted October 15, 2012 - 07:59 AM
No problem! Depending on how heavy the table I'm getting is will determine if some type of rollers will get used. I might want to move it around! But the casters/rollers would need to work on grassy areas too!
