Added A Bolens To The Herd.
g152
53 replies to this topic
#31 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted December 21, 2012 - 11:25 AM
The tiller is done being 're-freshed'. http://gardentractor..._15#entry249827
I am now going to start on doing the snowblower. Needs some straightening on the sides, some wings to widen it out another 4-6 inches, some straightening of the auger, and the cups in the center of the auger need to be re-done. I am also going to replace or build a new chute for it.
I'm also working on the broom I picked up Saturday. Since it takes 5 bolts to remove the snowblower from it's sub-frame, I'm going to mount the broom to the same frame.
I have an extra small hydraulic cylinder that came with the Bolens, so I'm going to try to set the broom up for hydraulic angle. I'm also trying to figure out how to use the same cylinder to get hydraulic swivel to the snowblower chute, but it doesn't have a very long stroke to it.
Like the tiller, the blower has good decals on it. I will leave them alone. It is getting painted black and white. (where appropriate)
#32 Cvans ONLINE
  • 7,282 Thanks
  • 6,376 posts
Posted December 21, 2012 - 11:50 AM
I've enjoyed following along with your project. I have one question concerning the snow thrower. Why are you adding wings? Is it narrower than the tractor?
#33 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted December 21, 2012 - 01:19 PM
Yep, the tire chains cut into the bank when going straight, on both sides. 42" blower, 44" width at the rear tires.
#34 Cvans ONLINE
  • 7,282 Thanks
  • 6,376 posts
Posted December 21, 2012 - 01:55 PM
That little beast has a wide stance.
#35 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted December 21, 2012 - 02:07 PM
I am also going to swap my two Sweepster broom heads. I'll put the 48" head off from the Homelite broom onto the gearbox for the Bolens. The 36" unit will get put on the Homelite. The actual broom heads are interchangeable. I need to replace the sprockets that run the #40 chain on the 48" broom, it throws the chain if it hits a lot of resistance.
Might as well have the 48" on the bigger tractor, so it covers the width of the machine.
#36 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted December 23, 2012 - 08:49 PM
Great lookin' Horse you picked up. I did own an old tube frame Bolens, great equipment.
Good luck! Very nice! :thumbs:
  • Cat385B said thank you
#37 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted December 25, 2012 - 11:24 PM
Going to start fabbing up a mounting system tomorrow.
  • Bolens 1000 and marlboro180 have said thanks
#38 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 18, 2013 - 02:49 PM
Well, the broom got delayed, but I'm back at it. I had to order new knuckles since it has a wider broom head on it now. Couldn't find a used one over the course of a week, so I gave in and ordered one. 7/8" hexagon shaft.
Ground off the old framework from when it was upside down on a Kubota:
I'm using the snowblower frame to mount this, single pin with some pipe welded in to keep it somewhat tight. I went with a 3/8" pin to control the swivel because the small hydraulic cylinder I got with the tractor leaks. It needs to be rebuilt, so manual angle for now.
Had to lengthen the pto shaft back to the tractor. It's 7/8" x 3/4" inch shaft, I had to add on 2" or so.
Done and fits:
Now I'm working on getting the tensioner pulley to stay put. It keeps backing off when in use, single bolt mounting arm. I'm going to try welding a sleeve nut and using a bolt to keep it tight.
#39 Bolens 1000 ONLINE
  • 15,416 Thanks
  • 18,279 posts
Posted January 18, 2013 - 07:02 PM
Looks like your making good progress :thumbs:
Keep the pics coming!
#40 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 18, 2013 - 07:42 PM
That I can do. What I can't do is bend metal in a smooth curve. The original black plastic side cover to protect the chain for this one is broken. You can see one of the cracks in this pic.
So, 1/8" by 3" wide steel, 6' long. Here is what I ended up with: (got about 2" clearance to the tire when angled to the right)
Here is the hexagon shaft issue I was talking about earlier. On the old small set up, that stub shaft (left side, hiding under the new hex shaft) on the chain drive went right into the sleeve on the right.
Using the stub from the broom now mounted on the Homelite worked, but if I sell one or the other I better have one for each.
  • Bolens 1000 said thank you
#41 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 18, 2013 - 07:49 PM
Tomorrow's project is to get the plastic hood set on there and secured. Then, until these arrive, I'm done with it.
#42 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 19, 2013 - 11:51 AM
Oops, hit a snag. I cut a cover piece out of sheet metal from an old dehumidifier to fit in that side piece. Even on the lowest setting, the wire feed burns through it. Is this something that JB weld would hold up to if I kind of 'caulked' it in there?
#43 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted January 20, 2013 - 04:23 AM
What size wire do you have in the wire feed? You need the small stuff for sheet metal.
#44 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 20, 2013 - 09:29 AM
.023, I do believe is the size of the smaller wire that I use, Kenny.
#45 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted January 20, 2013 - 09:32 AM
And it still burns thru? Must be some thin stuff! Or your mig is just tooo big for that!
Also tagged with one or more of these keywords: g152
