Rebuilding My First Small Engine...need Help.
23 replies to this topic
#16 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 17, 2012 - 09:19 AM
Why would I have to mess with valve clearances if all I'm doing is putting new valve springs in it?
Sent from my HTC One X
#17 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted October 17, 2012 - 01:55 PM
More importantly, why would you want to put new springs on without checking for proper clearance? More than likely the valves/seats need lapping. This can change clearance, & likely the clearance is off as it is. No way to tell clearance until all is cleaned up & seating well.
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 20, 2012 - 01:03 PM
Where do I find model numbers for this? I need to see how much the parts will be before I go any further.
#19 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted October 20, 2012 - 01:05 PM
I would think they'd be stamped into the flywheel shroud.
#20 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 20, 2012 - 01:29 PM
That's the first place I looked. :huh: ... Nothing
#21 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted October 20, 2012 - 03:08 PM
I just looked a similar engine, but just 3hp, and the numbers are stamped into the side of the shroud, opposite the carb/exhaust side.
#22 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 20, 2012 - 09:08 PM
Found it. Thanks. Where's the best place to get a parts breakdown?
#23 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted October 20, 2012 - 09:12 PM
Try HERE click on the appropriate numbers line, then find your exact model for a parts diagram.
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 20, 2012 - 09:43 PM
Thanks again. I didn't realize parts tree also does engines.
