1968 110 Side Tag
146 replies to this topic
#121 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted September 05, 2014 - 05:51 PM
Finally got the dash off so I can see more of the mower engagement assembly.
Edited by Trav1s, September 05, 2014 - 05:57 PM.
#122 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted September 05, 2014 - 09:47 PM
Doesn't look that bad under the dash mine was worse and yours was outside in the tractor lot. I also see the mower deck belt looks the same
#123 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted September 06, 2014 - 09:20 AM
It is in pretty decent shape - better than I expected considering it sat outside for years with the hood removed. I am going to see if someone will sandblast the pedestal, fender pan, and hood supports for me. I will hit the other stuff with the wire wheel. Got the decals off of the dash last night too.
Edited by Trav1s, September 06, 2014 - 09:29 AM.
#124 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted September 06, 2014 - 12:52 PM
Travis, As nice as the 120 turned out and with all you learned doing it, I can't wait to see you restore this 110.
  • Trav1s said thank you
#125 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted September 06, 2014 - 01:29 PM
Thanks!  I want to do this one in base/clear, at least the hood, fender pan, and seat pan but will have to see how things play out.
#126 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted February 03, 2015 - 11:57 PM
Back from the lost threads...
I finally managed to snag a JD service manual for 110/112 tractors 100,001 - 250,000 for a reasonable price.  It arrived today and will be very helpful as I go a bit deeper in the teardown.
#127 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted February 04, 2015 - 10:59 AM
Here are a few pics of the manual.  It really is in great condition and has lots of life in it. I hope to use it to figure out the original Magneto ignition system on it.
Edited by Trav1s, February 04, 2015 - 12:25 PM.
  • hdg4400 and Navy Chief have said thanks
#128 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted March 27, 2015 - 09:32 PM
Hows the rebuild going?
#129 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted March 28, 2015 - 02:28 PM
Still in the great holding pattern as I work on the 312... I figure that time and $ put in the 312 will serve me better than the 110.  The 312 is going be used to blow snow in the winter with the 49 blower.  Considering my first 2 winters back In Iowa that is a wise decision.
Edited by Trav1s, March 29, 2015 - 08:00 AM.
  • Texas Deere and Horse and Navy Chief have said thanks
#130 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted January 30, 2016 - 12:27 PM
Holy cow...
Almost a year so an update is appropriate but past due:
The 110 has been hiding in the garage due to cold weather and lack of time. This morning I managed to do a bit of work on it in the name of maximizing space. I removed the engine from the frame and will take some time to clean it up and repaint it. I am 99% sure it was short blocked sometime in the 80s or 90s as the block is black and is NOT green under the black. It has good compression so I am going to take a chance on it. The frame is now sitting on end in the corner and gives me more room in the garage for my Jeep.
Edited by Trav1s, January 30, 2016 - 12:30 PM.
  • RAJ said thank you
#131 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted January 30, 2016 - 06:05 PM
The other thing I noticed is that the under side of the frame is in really nice condition with original paint.  I am going to power wash it and see how it looks.
#132 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted January 31, 2016 - 10:34 AM
If you don't want to chance the motor, use the one on the wall in the last pic.......
#133 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted January 31, 2016 - 03:39 PM
Yeah... 4.25" bore with 3.375" stroke x 8 might be a bit much for a 110.
  • Cat385B said thank you
#134 Trav1s OFFLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted February 01, 2016 - 05:41 PM
Additional work this afternoon included removing the mower deck (which seems to be pretty solid) and messing around the k181 in the tractor.  I pulled the head and there is minimal carbon, the head gasket looks relatively news, and the found piston is free, valves move and little to no ridge in cylinder wall!!  I really want to try to start it but the wiring harness is a MESS.  I will order a new ignition switch/wiring harness and rebuild the carb before I try to fire it up.
I forgot that I had the head off of it.  Looking back on the pics I am good with running this engine as is.  I wish we were getting a week of temps in the 40s instead of more snow but that is expected in Iowa in February.
  • Navy Chief said thank you
#135 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted February 06, 2016 - 02:00 AM
Holy cow...
Carb looks new
