Is It Too Late To Sew Grass?
14 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 12, 2012 - 03:17 PM
I have been planning to sew a grass cover crop on my garden.
The new tiller came in yesterday and I should have it ready to go tomorrow.
We are expecting rain tomorrow too. Ground in a normal year would not freeze til late November or early December (thats not to say anything has been normal this year).
Do you think it would be too late to sew a pasture mix this fall?
The mix I'm looking at is 70% Tall Fescue.
Edited by JD DANNELS, October 12, 2012 - 03:20 PM.
#2 olcowhand ONLINE
  • 41,025 Thanks
  • 31,379 posts
Posted October 12, 2012 - 03:22 PM
If you keep enough moisture, it may do ok, but I'd add some winter rye in the mix as it comes up quick & would provide cover while the young fescue comes along.
  • JD DANNELS said thank you
#3 JDGuy445 OFFLINE
JDGuy445
  • 356 Thanks
  • 428 posts
Posted October 12, 2012 - 04:22 PM
We planted rye this year and it comes up really quick. My reccomendation is find a small spring harrow if possible. Broadcast the seed and then run it over with the spring harrow. It helps to come up. Seeing your in Iowa you should be good for a bit. But I would also add something else in like rye.
Edited by JDGuy445, October 12, 2012 - 04:22 PM.
#4 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted October 12, 2012 - 06:42 PM
I was always told that you sow grass in months that have an "R" in them..October, November, etc
  • JD DANNELS and IamSherwood have said thanks
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 12, 2012 - 09:05 PM
Hmm I wonder if there is anything that R rule does not apply to? I had not heard that one, but have known for a long time you could harvest fur bearers in months with an
R( course that started a long time before Game Laws).
We are going to give it a go. I'll finish assembling the tiller tomorrow and as soon as it is dry enough I'll till and plant.
Edited by JD DANNELS, October 12, 2012 - 09:06 PM.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 12, 2012 - 09:11 PM
I don't have a spring tooth harrow, but have 3 4ft sections of spike tooth harrow. These are old and were probably used with horses I can adjust the depth .. Since my tractor has a wheel width of 47 3/4" so the 4 ft harrow works well. I know that because after I graded my lane I pulled one section weighted ot see if I could pull up some gravel out of the hard pack.that did not work at all badly. Dad had some of these and we seeded pastures and sowed oats with them when I was a kid. So I'm sure it will work.
Edited by JD DANNELS, October 12, 2012 - 09:14 PM.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,997 posts
Posted October 12, 2012 - 09:12 PM
If you cover it with straw, it will have a chance. Not so much as an insulator, but to keep moisture trapped in contact with the seed/plant.
#8 olcowhand ONLINE
  • 41,025 Thanks
  • 31,379 posts
Posted October 12, 2012 - 09:16 PM
With winter rye, it comes up so fast that it will act as a cover & hold moisture. Neighbors down the road just worked their yard real fine, then sowed grass. Came a gully washer & ruined the yard work, washing it bad. This time he smoothed the ground & sowed winter rye along with the grass. in a week he had 4" tall rye!
#9 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted October 12, 2012 - 09:55 PM
A cultipacker always worked the best in this area before and after seeding , anytime of the year ( a reasonable time of year ). We had a local Colonel " Mac" who could plant rye or wheat in early Nov and make it grow. He flew Kissinger into N. Vietnam in 73 and later became AF 1 pilot . The ground would do things for him that most wouldn't try. Add: actually it is the culti-mulcher with springteeth that is used in field work. But if you could do something equivalent the results are the same.
#10 JDGuy445 OFFLINE
JDGuy445
  • 356 Thanks
  • 428 posts
Posted October 13, 2012 - 07:23 AM
That should help. The rye will come up even faster with that. Also do you know if you can get some fertilizer somewhere?
#11 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted October 13, 2012 - 07:43 AM
The fellow that I bought the DB walkbehind said when he planted his cover crop he used the spike tooth harrow , then broadcasted the seeds and went over with a yard rake upside down to fill the little trenches with seeds ( I think a board pulled behind a tractor ona large scale would work ) made it look like the seeds where drilled .I got a DB harrow packer with it but he didn't say he used that too or not . I used it instead of raking when I did the cover crop in one section of the garden , hope to finish planting the cover crop this week . Al
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 13, 2012 - 01:00 PM
Yes, there are 3 bags of miracle grow fertilizer out in the shed.
Dad had done some seeding over at the church about 2 yrs ago and Walmart was closing it out due to season change.
He had bought 6 bags for $1 each and bought more than he needed. So he gave me the extra.
#13 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 13, 2012 - 07:38 PM
I was told to sow, just before the first snowfall. Holds the moisture, and keeps the birds away.
I'm going to give it a try this year, with some triple mix.
  • Team_Green said thank you
#14 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted October 14, 2012 - 05:43 PM
Iver heard the same thing..
#15 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted January 03, 2013 - 12:04 PM
Add the winter rye, will germinate quicker. Let the rye grow a bit before adding the fescue seed.
In addition to providing cover, will hold the fescue seed in place. Great Best time of the year to spread grass seed.  :thumbs:
Edited by Tankman, January 03, 2013 - 12:07 PM.
