What Model Is This? Its A St10 - Refurb Time.
44 replies to this topic
#16 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 13, 2012 - 12:59 PM
Is it yours now David? Good looking little tractor! The weights are from small Farmall front wheels.
#17 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 13, 2012 - 01:19 PM
How much do they weigh? And yes It's mine. I noticed some bolts on the trailer when I got home. The deck is coming off as I got this tractor for playing and plowing. I did now with it for a hour. It did well. First impressions are good. While I hate the paint it was done right. I noticed the side wall leaking antifreeze on the rears so they will be pulled off and tubed
Sent from my HTC One X
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 13, 2012 - 04:41 PM
Some if of the parts that came with it. Everything came from Sears. Wonder if he replaced the gear boxes or if he ordered these as extras. They appear fine. How many blade collars does one need?
#19 MH81 OFFLINE
Posted October 13, 2012 - 04:59 PM
Good for you. Super news anothe Sears has found a good home.
Re: blade collars. Those are designed to be break away. If you hit much of anything with it, that collar turns to pieces. When my parents first put in their back yard in the late 60's, that pile would've been one or two summers mowing.
#20 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 13, 2012 - 05:04 PM
I see. Thanks for the info.
#21 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 13, 2012 - 07:33 PM
They are "gearbox savers" so to speak. they act the same as a "shear pin" in a piece of farm equipment.
#22 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 13, 2012 - 07:58 PM
How do I tell if these spare gear boxes are any good? They have no play any feel fine when you spin them.
#23 MH81 OFFLINE
Posted October 13, 2012 - 09:53 PM
You just tested them how I would. I'd also pull the 4 little bolts out of the cover and check for obvious wear or metal flakes in the grease.
Since you have it open, good time to refresh, replace, refill the grease in there. Use the good stuff. I think Dad always used the really sticky bearing grease in his.
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 22, 2012 - 04:55 PM
I went to wash it today. The green paint came off. Heres the thread...http://gardentractor...o-remove-paint/
#25 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 22, 2012 - 05:00 PM
This is the mess I'm in now. I have a feeling ill have the ugliest tractor at the plow day. I'll be painting it this winter. Enamel? Is that the paint I need? What's this lever for?
#26 MH81 OFFLINE
Posted October 22, 2012 - 05:53 PM
I would much rather have the ugliest tractor at plow day than the prettiest one NOT at plow day.
Don't worry about looks, Daniel has an "Ugly" BH you can park it next to if it starts feeling under dressed.
#27 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 23, 2012 - 03:07 PM
All flat areas had some prep so I couldn't save the oem paint. Oven cleaner didn't work. Graffiti cleaner didn't work either. This stripper did on the non preped area. I painted some engine tin and fenders with rust converter. This cat yellow is off from cat yellow but is a dead on match with sears.
#28 MH81 OFFLINE
Posted October 23, 2012 - 05:16 PM
Wow, in that 1st pic, the 10 looks like it just got done with an all day paintball tourney.
Are you doing a full-on painting now or just a touch up on the trouble areas?
#29 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 23, 2012 - 05:51 PM
I'll do a full repaint this winter. I learned a lot with the allis last winter (several things I have to redo on that one). I'm really liking the new paint from tsc. I'll use it and see how it holds up next year to the work and the summer sun.
#30 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 25, 2012 - 07:48 PM
I went to put the fenders on for plow day. As of now I like the new paint from tsc. It goes on thin but covers well. I only put one coat on them until I sand down and repaint the whole thing.
The color looks bad in the pics but you get the idea. I also noticed I've got a rear seal leaking.
