What Model Is This? Its A St10 - Refurb Time.
44 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 01:32 PM
http://lexington.cra...3313148455.html
Pros and cons of this model? Is the price about right?
Sent from my HTC One X
Edited by BairleaFarm, October 22, 2012 - 04:55 PM.
#2 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted October 12, 2012 - 01:51 PM
Sears Custom 10?? ST10?? I'm thinking ST10.
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 02:21 PM
He says hes for extra blades for the deck belts gear boxes(???) Voltage regulators and other stuff. He says it's got a 10hp tecumsie (sp). Runs and drives.
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 02:30 PM
I'm trading some stuff and cash. All said and done I would have about 350$ in it.
#5 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted October 12, 2012 - 03:12 PM
:picsoritsnotyours: ............ Once you get it home of course!
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 03:25 PM
The deal isn't final. How do these things plow? With a plow or front blade.
#7 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted October 12, 2012 - 05:48 PM
They will plow along side any in it's class. It will pull a 10" plow with weights added, but was designed to pull the Sears 8" plow.
#8 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 06:35 PM
As it just so happens I've got both. :p
#9 MH81 OFFLINE
Posted October 12, 2012 - 08:51 PM
My SS12 will pull the 10 without much problem at all. More traction issues with the turfs than anything else.
The tractor is nimble and has more power than you'd think for the size of the engine. Now for the con.
With the flat bar front end, (Custom series used it too) you can use a snow plow with the proper bracing (you'll break the steering gear without them) but I wouldn't use that style too much for heavy dozer work.
Also :ditto: to it being a ST10 with a previous owner that had some extra green paint.
#10 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 08:59 PM
So is there a support something that goes with this grader blade? Is it pictured lol?
#11 MH81 OFFLINE
Posted October 12, 2012 - 09:00 PM
No, I mean if you use a front blade on it.
Let me see if I can find an old post.
  • BairleaFarm said thank you
#12 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 09:14 PM
thanks. I said grader but i ment the front blade.
on edit: I dont think it really matters. I looked at the pictures again. Its a rear 3ph blade that comes with it not a snow blade.
Edited by BairleaFarm, October 12, 2012 - 09:17 PM.
#13 MH81 OFFLINE
Posted October 12, 2012 - 09:18 PM
OK, found the post.
http://gardentractor...ece/#entry27374
#14 MH81 OFFLINE
Posted October 12, 2012 - 09:20 PM
Someday I will find a grader blade for mine. I will just keep looking . Saw one last fall but they wanted 250 for it. It was really rusty and they could only see brown gold. Didn't even try to haggle.
#15 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 13, 2012 - 09:57 AM
This is basically a one owner tractor. The owner gave it to his neighbor in exchange for some work. The guy didn't need it. All manuals included. Only engine work that's been done was a head gasket years ago and rear tires. Gear shifters and levers are stiff from sitting.
