Jd 314 Exhaust Repair
8 replies to this topic
#1 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,503 Thanks
  • 1,076 posts
Posted October 12, 2012 - 10:44 AM
I noticed this slot worn in the exhaust nipple. I guess the bolt fell out of the muffler bracket and it ran that way for quite awhile rubbing on the hood support. Cleaned the area up w/ a flap disc and torchwelded it, Smoothed out the weld and was able to reach inside to clean gobbers off the inside w/ the die grinder.
Mike
#2 JDBrian OFFLINE
  • 9,593 Thanks
Posted October 12, 2012 - 05:07 PM
Nice repair Mike. That must have been loose for a while to wear through like that! The hood support must have been interfering with exhaust flow by the looks of how deep that is. I have a 314 and I am wondering if your motor mounts are OK. It's a common problem with them. If they are shot the engine will move a lot more than it should.
  • ol' stonebreaker said thank you
#3 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,503 Thanks
  • 1,076 posts
Posted October 12, 2012 - 05:43 PM
It appeared to me the bolt fell out of the muffler bracket and let it swing down. It was in and tight when I noticed this.
Mike
#4 Alc ONLINE
  • 5,916 Thanks
  • 6,884 posts
Posted October 12, 2012 - 08:22 PM
Nice repair :worshippy1: I never gas welded enough to even try something like that ., Al
#5 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,503 Thanks
  • 1,076 posts
Posted October 12, 2012 - 09:19 PM
Best technique I've found for thin stuff is to keep the flame almost parallel w/ the parent metal.
Mike
#6 JDBrian OFFLINE
  • 9,593 Thanks
Posted October 13, 2012 - 05:55 AM
Very well done. You don't see a lot of posts about gas welding these days. Your repair makes a good case for it's continued use!
#7 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted October 13, 2012 - 07:40 AM
Nice looking repair work,I have to agree with what's already been said,it sure is good to see someone break out the torches and go to work! :thumbs:
#8 thirdroc17 OFFLINE
thirdroc17
  • 36 Thanks
  • 91 posts
Posted October 13, 2012 - 11:08 AM
Job well done! My gas welding skills SUCK! Sure would be nice to have your torch talent.
#9 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,503 Thanks
  • 1,076 posts
Posted October 13, 2012 - 01:13 PM
It just takes practice.I've been "practicing" for 50 yrs. Get a bunch of scraps from a muffler shop and practice on them. Don't pick any that have the aluminized surface 'cause it makes it more difficult.Use a small tip and keep your flame small,just enough so it won't backfire, and as I said keep the flame almost parallel w/ the parent stock. I try to pass on my skills to other folks.
Mike
  • thirdroc17 said thank you
