Guess What I Got? A D4-12!
69 replies to this topic
#31 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted October 12, 2012 - 07:49 AM
First one I've ever seen, good find, that seat looks comfy , lol !!! How many horse is that Wisconsin ?
It's a 12hp Tecumseh engine.
#32 Lmiller3358 OFFLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted October 12, 2012 - 09:24 AM
Oh ok, thanks, Thought i saw wisconsin somewheres, my mistake
#33 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted October 12, 2012 - 09:50 AM
Easy enough mistake. Many Bush Hog models used TEC or Wisconsin, while the JB series was exclusively Briggs.
  • Texas Deere and Horse and Lmiller3358 have said thanks
#34 Texas Deere and Horse ONLINE
  • 14,811 Thanks
  • 15,500 posts
Posted October 12, 2012 - 02:54 PM
Daniel, Here is a couple pictures from under the tractor on the high/low lever.
  • olcowhand said thank you
#35 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted October 12, 2012 - 03:10 PM
That is odd. All others with this type transmission just have the shaft coming from the transaxle without any extension through the cover plate. It would appear to be OE being the upper plate is the correct red. At the same time, it makes me wonder if this was added by an owner for some odd reason??? Seems though if it were OE, the extension shaft would be butt welded instead of bent & welded to the flat lever.
#36 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted October 12, 2012 - 08:49 PM
Nice looking machine! Can honestly say I don't ever recall seeing a Bush Hog GT in person.
#37 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 13, 2012 - 09:15 AM
I'll snap some of mine today when I get back to compair.
#38 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 21, 2012 - 01:48 PM
Mine looks about the same from under neath. Shifting this beast I am still having issues though. I have all of my gears, however my clutch does nothing. I have to turn it off, shift gears then start back up. I took the clamshell cover plate off on the right side and saw everything was moving as it should at least I think it was.
What would be causing it not to shift into gear?
#39 Texas Deere and Horse ONLINE
  • 14,811 Thanks
  • 15,500 posts
Posted October 21, 2012 - 07:36 PM
Peter, I don't know what the problem could be. Is your clutch releasing in the bell housing? That is the only thing I can think of that would cause your issue.
#40 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted October 22, 2012 - 06:38 AM
Could be the disc is stuck to the flywheel and not loosening when you push the pedal down.
#41 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 22, 2012 - 06:45 AM
I'll post a video hopefully today of what's going on in there and get your opinions. Thanks!
#42 MH81 OFFLINE
Posted October 22, 2012 - 07:05 AM
I know exactly zero about the BH trannies, but are your brakes adjusted up? The Massey, WH, and Sears all like to have their brakes proper, otherwise they have a tendency to grind.
#43 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted October 22, 2012 - 08:05 AM
I've mentioned that before & suspect this is the case.
#44 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 22, 2012 - 09:24 AM
^ Yep you said that about my other one. Now if that is in fact the case here, how would I go about correcting it?
Would it be a matter of just spraying it with some kind of lube and letting it sit or would I need to take the entire thing apart?
Edited by Titus, October 22, 2012 - 09:25 AM.
#45 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 22, 2012 - 10:12 AM
Brakes feel good, but I will inspect that as well.
Is the clutch disc (I assume that's what you're talking about?) Part S8-18 in the D4-10 manual sticking, is that a common issue?
Looking at the manual, you're thinking it's sticking to S1243 the clutch shaft?
