Vertical Vs Horizontal.
6 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 11, 2012 - 11:03 AM
Are horizontal motors better because of torque? I could easily convert the allis to horizontal if I came across say a 20hp vertical shaft engine.
Sent from my HTC One X
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted October 11, 2012 - 01:18 PM
Torque is torque no matter the orientation of the crankshaft.
"I could easily convert the allis to horizontal if I came across say a 20hp vertical shaft engine."
Did you get the terms reversed in your statement?
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 11, 2012 - 01:26 PM
I did.. can convert it to horizontal.
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 11, 2012 - 01:27 PM
Crap.. vertical. It's of coarse horizontal now but I could make it vertical.
#5 lyall ONLINE
lyall
  • 2,015 Thanks
  • 1,525 posts
Posted October 11, 2012 - 08:58 PM
vertical and horizontal are very different
if you turn a vertical into a horizontal or a horizontal into vertical they will not last very long
oiling the motor is the problem even it it a pressurize
the oil have to drain to the bottom of the motor to get pumped or splashed round inside
some parts must exchange but not many because of how they are designed
#6 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted October 12, 2012 - 07:28 AM
they are exactly the same for power. So there is no point changing it
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2012 - 07:42 AM
The reason would be... A messed up 10hp k series that's bad and a 20hp vertical sitting on the shelf.
