What's Your Opinion...
16 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 08, 2012 - 11:49 AM
On electric lifts.? Either 3ph or mid lifts? I've got several actuators floating around.
Sent from my HTC One X
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted October 08, 2012 - 12:04 PM
Sure would beat a manual lift!
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted October 08, 2012 - 12:08 PM
The electric lifts can be hard on the charging system. If I use the one of my CC129 quite a bit like tilling the garden, it will heat up the S/G. I think that's what burnt it up the last time.
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 08, 2012 - 01:35 PM
Wonder how they would do on a rectifier system. I think I'll use one for the sleeve hitch on the allis for the up coming plow day.
#5 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted October 08, 2012 - 06:28 PM
Don't know about your tractor's electrical system, but I love the one on my Johnny Bucket Jr.! No strain or pain on the charging system. The gen light will show when I pick up the bucket right after tractor hasn't been in use for a day or so, but the next hoist the light stays off. I could wind up the engine more for that first one, however I'm still a "slow warmer-upper".
#6 caseguy OFFLINE
  • 1,627 Thanks
Posted October 08, 2012 - 06:34 PM
I think that member wvbuzzmaster (Casey) added a GM alternator to his Caterpillar to offset the problem of overtaxing the electrical system with the electric lift he added. Hopefully he'll be along to share more of the details.
  • wvbuzzmaster said thank you
#7 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted October 08, 2012 - 06:43 PM
The battery should have all the reserve in the world to operate the lift, so I don't understand why it would tax the charge system, except used a lot, would drain the battery. The charge system shouldn't be harmed, as they are designed to put out a max amount for extended periods.
#8 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 08, 2012 - 07:02 PM
Well, someone has forced me to chip in (thanks Steve haha). I am using a 2000 # electric winch to lift the sleeve hitch on my Caterpillar (Craftsman) GT. I added a 37 amp Delco Remy (3 wire GM) alternator to the tractor for 3 reasons. The first was to offset the fact that my charging system wasn't working to begin with, second, my winch had more power demands, and third.. it is an over the counter part at just about every auto parts store. My goal with the tractor has been a well rounded working tractor, and part of the requirements of that was all parts had to be automotive lol. It works great, and the only flaw is that the lawn and garden battery is ever good enough to outlast my abuse to it which includes using it in a deep cycle fashion to winch heavy loads indoors with the tractor not running lol. Other than that (small usage violation) you would be all set. Search for "Caterpillar sleeve hitch" and you will find a couple threads more in depth.
#9 DH1 ONLINE
DH1
    Electric Tractors
  • 5,243 Thanks
  • 5,552 posts
Posted October 08, 2012 - 07:13 PM
You need a bigger battery, it's the Battery that powers you electrical attachments, the Alternator or Generator charge the battery.
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 08, 2012 - 07:19 PM
I can,t say i have ever used one, but I like the idea. My Murray Yard Pro seems like a good candidate and when i get a sleeve hitch made for it the actuator is in the plans. I have several ideas I have stolen over time i would like to work int the plan. I saw a guy on another site use a 2 inch reciever to mount the actuator and I like the quick removal snap in system used on the Johnny hitch.
The combination would allow one to remove the hitch and actuator and store it out of the weather when not in use and a trailer light connection would make it all quick.
#11 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted October 08, 2012 - 08:33 PM
I use a deep cycle battery for a boat on my 129. It has a 2000# winch to raise and lower the snow plow. I have never had a problem with the s/g heating up and when I am done with the winch I let the tractor run for a bit to charge the battery.
Geno
#12 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted October 11, 2012 - 02:39 PM
from what I've read regarding what battery to use for winching (in the off-roading community) all of the experts claim that a normal car battery is better for winching than a deep cell. Supposedly deep cells are designed to drain long and slow whereas car batteries are designed to take a sudden hit (inrush) of several hundred amps (starting an engine or sucking in a winch). Of course the winches we use are a minimum of 8000 pounds.
my take, if you need more juice for winching get a bigger normal style battery. if you want to be able to run your radio and rock lights for hours with the engine not running get a deep cell and have it isolated.
I know for large winches, relying on an alt to run it is not good. If anything it will kill the altinator. Besides even bigger alts only put out between 130 and 160 amps. my jeeps winch sucks a little over 400 amps at start.
Edited by twostep, October 11, 2012 - 02:45 PM.
#13 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 11, 2012 - 02:49 PM
That makes sense twostep. I'll know shortly how it works
#14 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 11, 2012 - 05:57 PM
I have the HF 2000 # Winch mounted to mine to raise and lower the sleeve hitch & box scrapper. I also use it to pull tractors (that are not running out of the compound up a small hill. All I have is the original battery (11 years old) and the charging system that came with it. When Ii operate the winch I can see the hit on the amp meter but it charges for a couple of seconds and then returns to a low charge.
#15 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted October 12, 2012 - 05:03 AM
On any tractor that has room, I use an automotive battery. Then if I use something with a 'high draw', it doesn't tax the system too hard.
  • twostep said thank you
