Suburban 12 Coil Kill Wire ?
17 replies to this topic
#1 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 04:08 PM
I am in the process of completely re-wiring my Suburban I have managed to get everything done except the coil kill wire. I am not really sure where it goes on the coils as there was no wire on it the PO had everything hacked up.
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted October 06, 2012 - 05:01 PM
DB suburban or Sears (Roper) suburban?
I'm assuming Sears (Roper),
The wire electrically shorts the points together. Physically, it goes from the wire connection on the condenser back to the ignition switch. Grounds out for kill.
I have also seen them connect to the points, but I'm pretty sure that was a "custom wiring job" even tho it did work.
You do have the OEM switch in there, right?
  • mmclaughlin said thank you
#3 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 05:32 PM
Yes, I purchased a new switch with the big copper lugs. So I just run the wire from the switch to the condenser ?
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted October 06, 2012 - 05:35 PM
Yep, if it's the Roper style Suburban with the points, thats where mine went and it looked original.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted October 06, 2012 - 05:41 PM
If you look at the mount plate for the engine shroud, do you have a piece of plastic mounted at the 8:00 position?
If so, the wire goes there and another to the condenser.
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted October 06, 2012 - 05:42 PM
What year and model is this? I might be able to find a diagram somewhere.
#7 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:28 PM
67 super 12
#8 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:29 PM
yes that is where the wire from the points and condenser is attached to, the only thing they had right on the entire tractor, lol
#9 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:31 PM
whats the purpose of the plastic piece ? mine looks kinda brittle some pieces breaking off
#10 MH81 OFFLINE
  • 29,979 Thanks
Run your kill wire to that screw.
(Hey, where's the pics?)
#11 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:32 PM
here is a pic
#12 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:33 PM
and another
#13 MH81 OFFLINE
  • 29,979 Thanks
We posted at the same time, sorry.
The plastic is an insulator. If it was metal, it'd just be a short & you'd never get spark.
If you think yours is brittle, some of the really old ones had bakelite. All the worst properties of plastic & glass in one substance.
#14 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:35 PM
Thanks for all the help
#15 mmclaughlin OFFLINE
mmclaughlin
  • 72 Thanks
  • 149 posts
Posted October 06, 2012 - 07:42 PM
http://tewarehouse.com/7-01612 is this the coil ?
Edited by JD212, October 06, 2012 - 07:49 PM.
