Briggs 12.5hp - Crankcase Bolts & Threadlocker
5 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted October 03, 2012 - 08:48 PM
When I split the 12.5 hp Briggs to change the crankcase gasket, I noticed two of the bolts weren't tight. A Google search tells me this is a common with the engine (aluminum block & steel bolts). Assuming that is correct, which thread locker would you folks go with: blue, red, high temp red, etc? What would you use for the engine mounting bolts, some of which where also loose.
Briggs 12.5 hp, vertical shaft, model 286707 0441 01.
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,414 posts
Posted October 03, 2012 - 09:15 PM
I use the Blue.
  • RoosterLew and New.Canadian.DB.Owner have said thanks
#3 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted October 03, 2012 - 09:48 PM
I use the Blue.
The next guy that takes those bolts out will not like you if you use anything but blue in aluminum. Lol
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 03, 2012 - 10:11 PM
That's mighty unusual. Usually steel bolts in aluminum threads manage to lock themselves very well when dry. I always put antiseize on them so maybe there's a chance of getting them loose the next time.
JMHO,
Mike
#5 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,414 posts
Posted October 04, 2012 - 07:42 PM
Well it is a 12.5 Briggs, the last three I had, including a 11 hp all had the pan bolts loose or completely backed out. I think this is common on the smaller hp vertical briggs
#6 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted October 16, 2012 - 07:20 PM
Yes, the Briggs 280000 series replacement bolts now come with blue thread locker applied to them & instructions to up the torque to 200 inch pounds. Seems they feel it is pretty "common" as well.
