Binder For Manuals?
20 replies to this topic
#16 Ryan313 ONLINE
  • 3,404 Thanks
  • 5,241 posts
Posted January 05, 2013 - 03:41 PM
It took a while, but I remembered to check at Wall Mart for dividers while Christmas shopping. I found a pack of 60 and it was $4 and change. I had a chance to put them all into the binder today. I have them separated, but I do not have dividers for the different categories.
They all fit perfectly into a 1 1/2" binder I already had.
9AAE9135-EDBC-460C-B8F2-357D27C97C99-234
I had about 7-8 left so I put my 4x4 sketches and a couple other papers in the back for safe keeping.
#17 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted January 05, 2013 - 05:14 PM
this is the way I organize all my manuals. Easy just to grab the appropriate manual when needed!
#18 KennyP ONLINE
  • 40,238 Thanks
  • 46,811 posts
Posted January 05, 2013 - 05:54 PM
That's a good way to do it, Ryan!
#19 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted January 05, 2013 - 08:35 PM
looks good ryan when i have books on my gt's ill look into that until then there on my computer
#20 glgrumpy OFFLINE
  • 8,746 Thanks
  • 7,983 posts
Posted January 06, 2013 - 02:03 AM
That's the way I started doing them now too. Best to get the better binders tho, they have offset rings and don't bind up so bad when closing and open easier. usually 1-1/2" fits most needs even with several types of mans in same folder. Using Adobe to print allows you to print all the odd pages first, then shuffle all the papers to starting order, set back in printer and do the even pages to print on both sides. That way you save paper and put one in each clear page. OR, if you have singles just put back to back in a single clear plastic, not one for each page. If they have enough colors (not always) you can get them the color of the tractor brand or close.  Next problem is finding a shelf big enough to fit them and they don't stack well w/out tapering off each other unless you alternate the back sides. Then can't read them all from one way to pick one out!
#21 wilberj ONLINE
wilberj
  • 5,054 Thanks
  • 5,615 posts
Posted January 06, 2013 - 02:59 AM
I have used alot of sheet protectors so far. :D
Two 4'' binders
