Power Steering Control Valves
5 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted October 02, 2012 - 03:32 PM
I am replacing a control valve on one of our fork lifts and thought it was very interesting that Hyster uses the same valve as JD. does in the 318 . Hyster does use a 4 port because they have no use for the hydraulics after the steering, it's only for the steering circuit.
2012-10-02_14-25-39_759.jpg 2012-10-02_14-25-50_545.jpg Left is Hyster, right is JD
2012-10-02_14-26-00_744.jpg 2012-10-02_14-26-25_200(1).jpg Left is Hyster, right is JD
2012-10-02_14-25-31_664.jpg Left is Hyster, right is JD
#2 JDBrian OFFLINE
  • 9,635 Thanks
  • 14,156 posts
Posted October 02, 2012 - 03:37 PM
That's interesting Brian. I suppose that there aren't that many companies supplying those small valves. Is that valve made in the USA? I'm not sure if the same company supplies the valves for the newer tractors. They could be supplied by Kanzaki (sp) the company that supplies the transmissions for the LT, GT and compact tractors. I think that company may be owned by Yanmar!
  • 14,862 Thanks
  • 15,511 posts
Posted October 02, 2012 - 03:55 PM
JD., I can't find a Man. name on either of them, so your guess is as good as mine.
#4 ducky OFFLINE
  • 1,988 Thanks
  • 4,107 posts
Posted October 02, 2012 - 05:10 PM
Interesting Brian. As a forklift Tech a good share of my life l have seen a lot of those obitrols.
They do fit a lot of different Applications.
Many of them are adaptable t
K
#5 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted October 02, 2012 - 05:41 PM
Brian, those are Ross model HGF Hydraguide power steering units. Simplicity has used them also.
I just uploaded a service manual to the manuals section:
http://gardentractor...service-manual/
Specs and other info can be found in this catalog:
http://www.goldwayfl.../Ross motor.pdf
Edited by achomesteader, October 02, 2012 - 05:54 PM.
  • olcowhand, Texas Deere and Horse and KennyP have said thanks
#6 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted October 02, 2012 - 06:23 PM
Thanks Greg, That will be very useful.
