Ford 1500 Shift Selectors
4 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 01, 2012 - 08:18 PM
Here is a shot of the dash and shift selectors. Leftt lever is a range selector for 4 ranges. Right is 3 speeds and reverse giving a total of 12 forward speeds and 4 reverse.
Edited by JD DANNELS, October 01, 2012 - 08:19 PM.
#2 Cvans OFFLINE
  • 6,295 Thanks
  • 5,990 posts
Posted October 01, 2012 - 08:44 PM
That tractor sure looks nice. Has it been repainted?
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 01, 2012 - 09:02 PM
I don't believe it has been repainted the way the paint has held up on the brake and clutch pedals and there is very little wear on the diamonds. I'm beginning to belive the 551 hrs on the proof meter.. The hood is faded, but I suspect a wax job would clean it up real well.
#4 KennyP ONLINE
  • 36,530 Thanks
  • 44,981 posts
Posted October 02, 2012 - 05:42 AM
That paint does look good on it. You shouldn't have a problem finding the gear to work in.
#5 Cvans OFFLINE
  • 6,295 Thanks
  • 5,990 posts
Posted October 02, 2012 - 10:16 AM
If that's the case you have found yourself a real peach of a tractor. Must have spent it's whole life hiding in the shed.
  • JD DANNELS said thank you
