Bcs Tiller Question
5 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted October 01, 2012 - 01:28 PM
I have an older model BCS tiller (from the 70's) and I lost all my gears forward and reverse over the weekend. I know what the problem is, it's the little roll pins that hold the shifter fork in place. This is by design as per my brother who used to be a BCS tiller. I need to find these roll pins and apparently they are metric. Does anybody know what size these pins are? Thanks.
#2 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted October 01, 2012 - 04:19 PM
Give these guys a call. I havent used them but I have heard great things about them. They should be able to help.
http://www.earthtoolsbcs.com/
#3 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted October 01, 2012 - 04:36 PM
Your brother was a tiller? I'm at a loss here!
#4 wilberj ONLINE
wilberj
  • 5,053 Thanks
  • 5,615 posts
Posted October 01, 2012 - 04:51 PM
:bigrofl:
#5 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted October 01, 2012 - 06:53 PM
Uh, ok, tiller DEALER. He's a bit mixed up but not that bad!
#6 chieffan OFFLINE
  • 10,903 Thanks
  • 6,926 posts
Posted December 23, 2014 - 08:28 AM
I have had that happen to my BCS also.  could not locate the right pin so drilled the holes out to use US Standard size.  That way when/if it happens again I will have the pin to replace it.
I re-motored mine with a B&S 9 hp with the BCS adapter and dry clutch.  Works a lot better but need to lock the clutch out in cold weather to start it.
