Wanted
Part Needed Ariens 16hp Gt
ariens 16 hp gt part
13 replies to this topic
#1 davearctic OFFLINE
davearctic
  • 11 posts
Posted October 01, 2012 - 09:58 AM
I am looking for a part that has been discontinued for a ariens 16hp GT model # 931010. The part number is 63102600. The parts is a housing that attaches to the flywheel and connects the drive shaft.
if you have this parts and what to sell please let me know or if your know where i may be able to find one please drop me a line.
thanks
dave
#2 JDBrian OFFLINE
  • 9,599 Thanks
Posted October 01, 2012 - 10:06 AM
Dave, have you checked ebay for that part. If the engine is a Kohler K series you may be able to use other adapters to connect to the shaft. If you post some pictures, there may be some alternatives available. You could also talk to a machine shop to see if they could repair what you have or make something for you.
  • davearctic said thank you
#3 Wm McNett OFFLINE
Wm McNett
  • 122 Thanks
  • 166 posts
Posted October 01, 2012 - 01:08 PM
Joe just listed some parts that may work the other day for a S-14
http://stores.ebay.c...4&_sop=10&_sc=1
#4 Wm McNett OFFLINE
Wm McNett
  • 122 Thanks
  • 166 posts
Posted October 01, 2012 - 01:11 PM
http://www.ebay.com/...=item564ccf8908
http://www.ebay.com/...=item564ccf879b
http://www.ebay.com/...=item564ccf879c
http://www.ebay.com/...=item2c686e2dae
#5 davearctic OFFLINE
davearctic
  • 11 posts
Posted October 01, 2012 - 01:12 PM
looked on ebay, nothing yet. I may end up at machine shop if i can't find it
#6 bhts OFFLINE
bhts
  • 1,460 Thanks
  • 2,157 posts
Posted October 01, 2012 - 02:22 PM
I just looked and you can still get it new just has a new number. The cost was way up there and you maybe better off going to a machine shop and having it bored and resleeved.
#7 davearctic OFFLINE
davearctic
  • 11 posts
Posted October 01, 2012 - 03:50 PM
everywhere i called said discontinued even though they list this part
#8 JDBrian OFFLINE
  • 9,599 Thanks
Posted October 01, 2012 - 05:36 PM
That should be fixable at a machine shop. What does the end of the shaft look like? Is it damaged as well? I can't see how that got so worn without wrecking the shaft. Perhaps the shaft was replaced but not the coupler. You could take both parts to the machine shop and get them to come up with a solution.
#9 shorty ONLINE
shorty
  • 4,987 Thanks
  • 5,036 posts
Posted October 01, 2012 - 07:50 PM
With the price of a new one where it is, it seems it would be reasonable to try to rebuild or find a used one. The idea of sleeving sounds the easiest so far, unless you can find a used one.
#10 davearctic OFFLINE
davearctic
  • 11 posts
Posted October 01, 2012 - 09:14 PM
still looking for used, no luck. The end of shaft is worn as well, no key. must have broken. i going to bring shaft and housing by machine shop an see if the can fix it
#11 Texas Deere and Horse OFFLINE
  • 14,725 Thanks
  • 15,469 posts
Posted October 01, 2012 - 10:35 PM
I have moved this thread to classifieds so people will know what you are looking for.
#12 JDBrian OFFLINE
  • 9,599 Thanks
Posted October 02, 2012 - 04:03 AM
If it's not too expensive you would be better off with the repaired assembly than trying to make a used coupler work on the damaged shaft. Both parts need to be in good shape for it to last.
#13 davearctic OFFLINE
davearctic
  • 11 posts
Posted October 02, 2012 - 06:52 AM
thanks brian, new shafts are still available and not to expensive $45. so if i can find a good used coupler i will get a new shaft. hopefully the machine shop van fix for a good price
#14 davearctic OFFLINE
davearctic
  • 11 posts
Posted October 05, 2012 - 06:48 AM
found the parts an ebay, thanks
Also tagged with one or more of these keywords: wanted, ariens 16 hp gt part
