Cold Bending Steel.
25 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2012 - 08:18 PM
I need to make a sleeve hitch. I need to bent a piece of flat stock and make it kind of u shaped. The ends will bolt to the axle. Do I have to heat it or can I just bend it in a vice?
Sent using Droid.
#2 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted September 30, 2012 - 08:22 PM
I bend things cold all the time, but those things are small and can be. It depends on how thick the steel is. If you bend it cold it may loose some strenght sometimes when bending cold steel it is hard to achieve a tight bend.
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2012 - 08:34 PM
Tight and accurate in a vice is hard. I thought about using the press like a brake. 45* is the sharpest angle ill do.
Sent using Droid.
#4 Fabman OFFLINE
Fabman
  • 257 Thanks
  • 374 posts
Posted September 30, 2012 - 08:37 PM
If you have a propane torch you should be able to achieve what you want.
#5 olcowhand OFFLINE
  • 40,384 Thanks
  • 31,180 posts
Posted September 30, 2012 - 08:41 PM
Super easy with a torch heated bright red along the bend line. If more than 1/4" thick, it's kinda hard to do without heat or a press. You can however grind a groove half way through the bend line, bend in the vice, then weld the groove back in after getting the angle needed.
  • caseguy and JDBrian have said thanks
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 01, 2012 - 04:43 AM
No torch. The grind and re weld would work too.
Sent using Droid.
#7 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted October 01, 2012 - 07:59 AM
My theory has always been: if I can bend it while it is cold, it will bend under load. If you need it to hold shape under load, find something you can't bend while cold. If it isn't going to experience heavy loads, cold bending is fine. A sleeve hitch sound like the type of thing that will get some heavy use.
#8 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 01, 2012 - 08:40 AM
You put enough force you can cold bend just about anything. I think the grind and weld method may be my best option. I think it will give me the best strongest results.
Sent using Droid.
#9 Cvans OFFLINE
  • 6,468 Thanks
  • 6,060 posts
Posted October 01, 2012 - 09:28 AM
There is another option available for heat that isn't used much anymore but is very effective. Years ago the carbon arc torch was very popular and is an item that I still find useful. They are very effective for heating steel and it eliminates the need for a gas torch set. Check out the following video for more information.
  • MH81, coldone, lyall and 2 others have said thanks
#10 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted October 01, 2012 - 10:02 AM
Very interesting. I have seen references to them but never seen one in action. Thanks for posting this.
#11 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted October 01, 2012 - 01:02 PM
Neat video thanks for sharing. Makes me want to go out and find one.
#12 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted October 01, 2012 - 05:28 PM
I may be wrong on this but I think that if you have an older oil burning furnace, you may have a carbon arc torch, or at least the making of a 110v ac version. I seem to remember the older furnaces as using a carbon arc system to ignite the oil. There was a high voltage transformer that powered the arc. May not be as large as the one in the video, but it would be something to start with.
#13 Cvans OFFLINE
  • 6,468 Thanks
  • 6,060 posts
Posted October 01, 2012 - 07:25 PM
I believe those ignitors use high voltage and very low amperage. I can't remember for sure but I'm thinking in the 10 to 15 amp. range. The amount of heat generated would be very limited at most. The fuel oil is introduced into the furnace as a fog which takes very little to ignite and thus a very clean burn. The ignitor elements in the furnace we had weren't much more than two wires with the tips spaced close together. Good thought though.
#14 caseguy OFFLINE
  • 1,627 Thanks
Posted October 01, 2012 - 07:28 PM
...I seem to remember the older furnaces as using a carbon arc system to ignite the oil...
I used to work for an HVAC supplier and the electrodes that we sold were all an alloy metal. I'm not sure what the makeup of them was, but they were chrome looking with a big ceramic insulator.
I'm wondering if the rods in that video are the same as the ones that we use at work with the air arc cutter?
#15 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted October 01, 2012 - 08:20 PM
Thanks for that video , I've seen those in the back of old magazine ads but never saw one in person nor being used. Al
