Kohler K341 Troubles
58 replies to this topic
#16 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted September 29, 2012 - 07:40 PM
Drill and tap it Doug. Lots of meat there. I had to do that to the K341 I got from you.
If that's so then I guess that's the answer.
#17 CASENUT OFFLINE
  • 505 Thanks
Posted September 29, 2012 - 07:44 PM
Ahhh...could you put a larger pulley on the decck? or smaller to get the rotation you need?
#18 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted September 29, 2012 - 07:47 PM
Checked Brian Millers Kohler engine site and he says 14 and 16 cranks the same.
#19 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
Posted September 29, 2012 - 07:50 PM
What....you didn't trust me? I'm hurt! :smilewink:
#20 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
Posted September 29, 2012 - 07:53 PM
If you drill, which is the best route, don't drill all the way through. Start the threading with a std tapered tap for ease of starting, then finish with a "bottom tap" to get threads near the bottom. I can measure a hole on a block I have here to tell you how deep to drill. Best to put a piece of PVC or copper tubing on the bit to control the depth without worry.
  • DH1 said thank you
#21 IamSherwood OFFLINE
  • 8,391 Thanks
Posted September 29, 2012 - 08:00 PM
Shouldn't one be able to drill and tap to the same depth of the existing hole?
Are there bosses inside there, or are all the blocks the same? I thought they where the same? :confuse:
And do as Daniel says, with a bottoming tap.
#22 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted September 29, 2012 - 08:03 PM
OMG delete my last post :laughingteeth:
I thought maybe because of larger bore, bigger piston, more reciprocating weight, the counter weight might be different but it's not.
#23 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
Posted September 29, 2012 - 08:05 PM
I figure all blocks have all possible mount locations with a boss on the inside, whether drilled/tapped or not. And yes, I'd say the depth of any of the possible areas to be drilled & tapped to be the same depth as those already in Doug's block.
#24 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted September 29, 2012 - 08:07 PM
I have the 14hp engine so I should try to make the new holes about the same depth as the the ones in the 14
Looks like the 2 bottom ones there's enough there, the top ones ???
Just checked to see if I could switch the pulley sets on the clutches but there different can't do it.
#25 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
I new dat! :smilewink: But you are smart to double check. Trust me! :rofl2:
#26 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted September 29, 2012 - 08:11 PM
Maybe I can do what some farmers around here do and just weld the clutch on, what do you think of that idea? :confuse:
:bigrofl:
#27 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
Posted September 29, 2012 - 08:13 PM
:bigrofl:
Sure would save a lot of time huh! :rofl2:
#28 IamSherwood OFFLINE
  • 8,391 Thanks
Posted September 29, 2012 - 08:17 PM
Just for FYI, here are pics of how I bushed the 1" shaft on a K341, to take a 1 1/8" clutch.
Those holes I drilled/tapped into the block, to the same depth as the existing ones, which are about
3/4" closer to the crank.
#29 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted September 29, 2012 - 08:25 PM
That's what I'd like to do but my crank is tapered for some reason and it doesn't look like it was made that way.
1" near the block, and 7/8" near the end. Must of had or tried to put this engine on a generator???
#30 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
Posted September 29, 2012 - 08:27 PM
That crank looks like a clutch was used for a long time with a failed bushing or something. Not even enough to have been machined. Looks like it's been worn down.
