What To Look For In A Jim Dandy
9 replies to this topic
#1 drhntrrmw OFFLINE
drhntrrmw
  • 3 Thanks
  • 15 posts
Posted September 28, 2012 - 06:03 PM
Hello All,
I'm new to this part of the forum but I am considering a Jim Dandy and I'm not sure what to look for as far as problems.
The one I am looking at is a 1974 Jim Dandy with hydraulics, mowing deck and snow plow.
It doesn't look abused but does need a good cleaning and TLC.
Help on what to look for before buying would be greatly appreciated.
Thanks,
Rob
#2 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted September 28, 2012 - 06:56 PM
welcome to the bolens forum need pics, in Christ
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 28, 2012 - 07:27 PM
The Jim Dandys came with two sets of gears. Some were very fast, some very slow. Don't know why they did this. Best thing to do when you look at it is to drive it in all the gears and see if you can live with whatever speeds it offers. These tractors are fairly bullet proof and if properly cared for will last many many years. Sounds like a pretty nice package. I can give you some tips on some things you'll want to take care of after you get it (if you do of course). Welcome to the insanity.
#4 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 28, 2012 - 08:45 PM
The first thing to check is the steering for slop, and if the steering column has any movement to it. Also, check the bearings in the transmission, spindle bearings on the mower deck and then the normal stuff to look at when buying any tractor. Good Luck! Like Jeff said, welcome to the insanity.
This is the first I have heard of the gear differences. Are you referring to the optional gear reduction box?
#5 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted September 28, 2012 - 08:53 PM
Rob maybe you could check the rear and trans fluid for water , maybe how the clutch throw-out bearing sounds when you push it in ( engine running ) I think you'll find there are pretty HD if not abused , Al
#6 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 28, 2012 - 09:04 PM
There may have been a gear reduction box come to think of it. I've only ever had one JD and it was FAST. All the rest have been larger models.
#7 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 28, 2012 - 09:12 PM
I do know that the Jim Dandys have smaller bull gears in the final drives. Making them faster, but they put less power to the ground.
I attached a picture of a gear reduction box, it was only available for the Jim Dandy models.
  • David Brown said thank you
#8 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 28, 2012 - 09:17 PM
The problem is, the box over corrected the problem.
#9 drhntrrmw OFFLINE
drhntrrmw
  • 3 Thanks
  • 15 posts
Posted October 01, 2012 - 12:03 PM
What is a reasonable price for one of these tractors in nice runnable condition?
Includes mowing deck, snow plow and hydraulics.
Thanks,
Rob
#10 Buggyman OFFLINE
Buggyman
  • 42 Thanks
  • 94 posts
Posted October 01, 2012 - 10:36 PM
I recently bought a 2418 for $800 with good sheet metal which runs and drives great... after I fixed a wiring problem. It included a deck and hydraulics.
