Arrrrrrgh!
26 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted September 28, 2012 - 02:34 PM
I'm about ready to put a bullet in my truck! My oil pressure sensor failed .... again! This will be # 8 since new in 2001, # 5 since Jan 2012. I've put in 3 Ford OEMs, and 4 from two different manufacuters.
It is a Ford Ranger with the 6 cylinder 3L engine. When the engine gets run for 60 minutes at 60 mph, the needle "gitters" when you pull off the highway and let the engine idle, like at an off ramp stop sign. If you turn the vehicle off, it acts normally again.
It is a pressure switch that feeds a fake guage. If you have more than 5 p.s.i. the guage sits at 1/2 scale. If you have less than 5 p.s.i. it drops to zero. When it acts up, it bounces wildly between zero and max.
My plan is to install a digital pressure guage and a new switch so I can get a real oil pressure reading when the guage goes heywire.
Anyone else faught this battle & won (or lost)? Any ideas?
#2 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted September 28, 2012 - 02:50 PM
Install the aftermarket gauge and forget the other. I would have done that on # 2 sensor!
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted September 28, 2012 - 04:49 PM
Does it require the sensor to allow the engine to run? SOme of them do...
I had an old Chevy, ripped the electric sensor out & installed a real gauge after a few "Low Pressure" readings. Worked fine till I got rid of it.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 28, 2012 - 06:12 PM
Some of us are slow learners. :blush2:
#5 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 28, 2012 - 06:44 PM
Might want to try to find a Ford Ranger "support group" forum on the internet. I have had very good luck when
problems arise with cars that I or others don't have an answer for, saved over 500 bucks on a repair for a bad fuel gauge
that I found was a very common problem by other owners, but the dealer had never heard of :(
P.S. the repair took 10 minutes and only cost 25 bucks for part. :thumbs:
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 28, 2012 - 07:09 PM
Might want to try to find a Ford Ranger "support group" forum on the internet. :thumbs:
A support group ... yes ... one with 12 steps ...
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted September 28, 2012 - 07:27 PM
Sounds like only 4 steps to go.... :laughingteeth:
#8 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted September 28, 2012 - 08:30 PM
Just wondering what motor you have ? Al
#9 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 28, 2012 - 09:14 PM
Not sure, other than it is called a "3 liter V6" here in Canada. 3 liters is about 183 cubic inches
#10 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted September 29, 2012 - 12:54 AM
I thought this was a belated talk like a pirate day post and was gettin ready to walk the plank.
Nothing else going on about that time??? Backfire nor temporary loss of power? I wonder where the oil pickup is on that thing and whether it is swimming in "muck". How about viscosity of oil. If you're running too high, it can boost oil pressure at certain temperatures and perhaps throw the sensor out with too much pressure. I'd feel it's not the sensor after that many tries and if it was a bad sensor all around, it would be all over the internet.
#11 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 29, 2012 - 08:18 AM
The only thing walking the plank is my truck.
No, nothing else going on. The engine runs like a swiss watch. Doesn't burn or loose oil. No extra noises. No stumbling or stuttering. The oil gets changed every 4,000 km with Castrol GTX 5w20 & a new Fram filter. The oil pan was off and cleaned two years ago.
The many stumbling block is that a new sensor fixes the problem for about 2 months. If it was something else, it should still be dead or dying when the sensor is changed.
#12 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted September 29, 2012 - 08:52 AM
I'll second John's advice as I've found some of the online owners forums to be great at helping solve odd vehicle problems,kind of like coming here for tractor help.It's been a while since I had my ranger but I do know there are some great ranger forum sites on the web.
#13 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted September 29, 2012 - 09:29 AM
If you have room at the sensor area, you can always tee-in a new guage and keep the old sensor in there.
#14 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted October 01, 2012 - 08:56 PM
I looked up your Ranger on Mitchell Repair Info . Intrusting thing they use a gauge which looks like it should have a variable resistance sending unit but the they use a " Oil Pressure Switch " like you said in your first post. One of the tests is to connect a 10 amp jumper from the sending unit wire and ground . Key 'ON engine OFF " should show normal . You said yours is bouncing I would try tapping the ground to see if you can get the gauge to act up.If you can't there might be something wrong with the dash cluster .There's a lot of things tied into the oil gauge that could effect it , way more then I would have thought ,I've repaired some of our International med duty truck dashes that had cracked solder joints and the trans temp gauge's ground was bad , it put the low air alarm on ! Yea I replaced a few " Low Air sw's before I found that lol , Al
#15 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted October 02, 2012 - 05:32 AM
I think to rule out the engine would be to keep the fused jumper on and drive it if the gauge acts up that will let you know for sure it's not the engine . Also check/clean all the grounds that you can find engine ones too . You never know , Al
  • MH81 and New.Canadian.DB.Owner have said thanks
