Rear tire help please, what should I buy?
8 replies to this topic
#1 4mer farm kid OFFLINE
4mer farm kid
  • 1 Thanks
  • 13 posts
Posted August 02, 2010 - 07:20 PM
I just picked up a 1987 JD 318. I want to put lug or Ag tires on the rear. Looking at Carlisle True Power or DURO - AG BAR LUG R1. The Duro tires are about $30 or more less per tire. Does anyone have experience with the Duro tires or the Carlisle tires? I would really appreciate any help you could send my way. Thank you.
#2 hydriv OFFLINE
hydriv
  • Validating
  • 71 Thanks
  • 583 posts
Posted August 02, 2010 - 07:28 PM
Why do you want to put tires on this tractor that are different to the OEM turf tires?
#3 4mer farm kid OFFLINE
4mer farm kid
  • 1 Thanks
  • 13 posts
Posted August 02, 2010 - 07:42 PM
I will not be using it to mow. I already have two mowers, JD GT235 and an eXmark zero turn. I have 9 acres and I will be using the JD 318 for a variety of ground engaging work and I will also be pushing snow with it. On the front I will be putting on tri-rib tires.
#4 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted August 02, 2010 - 09:42 PM
the carlisles are made in the usa. for $30 i wouldnt think twice about it.
#5 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 02, 2010 - 10:03 PM
These tires also have larger dimensions than others of the same size.
Check with Gene or Joe at Gearworks.com.
They are a sponsor and have a link on our home page.
He also just posted he has a real deal on 26x10.50x12s
#6 tractormike OFFLINE
tractormike
  • 166 Thanks
  • 1,488 posts
Posted August 03, 2010 - 06:03 AM
I have a couple sets of the Carlisle 26x12x12 tru power tires and really like the looks of them. Here is a picture with one set mounted on a Massey/Snapper 1200.176.JPG I don't have any experience with the Duro tires to help you out with them.
#7 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted August 03, 2010 - 09:29 PM
The duro tire is cheaper but the sidewalls are alot softer then the carlisle tire.I would not buy the duro tire unless money was a big problem and i was in a pinch.
#8 4mer farm kid OFFLINE
4mer farm kid
  • 1 Thanks
  • 13 posts
Posted August 03, 2010 - 11:05 PM
Thank you for all the advise! I will be buying the Carlise Tru Power tires. I already have a pair that will go on my 1968 JD 110 when I get it completed. I was hoping that I would like those. I'm sure I will. Now, I will have to order a pair to fit the JD 318. Thanks again.
#9 brzezinski01 OFFLINE
brzezinski01
  • 4 Thanks
  • 73 posts
Posted August 10, 2010 - 08:18 PM
[ATTACH=CONFIG]3952[/ATTACH]
where did you find tri-ribs that will fit?
