Need A Mower Deck Pulley. 42" Ford 120
5 replies to this topic
#1 Giantkiller OFFLINE
Giantkiller
  • 4 posts
Posted September 27, 2012 - 09:08 AM
Does anybody have a mower deck pulley for a 42" Ford 120.
Its the small blade pulley. don't need the whole mandrel,just the pulley.
Be glad to purchase. There is one on e-bay but the seller can't be contacted.
Any help or info appreciated. Dave. 757-434-1210
#2 KennyP ONLINE
  • 37,461 Thanks
  • 45,483 posts
Posted September 27, 2012 - 09:28 AM
Welcome to the forum!
Is the pulley on a 25mm spindle shaft? If you have the model # of the deck, it would help. I had to replace one on my deck. I thought the shaft was 1", but turned out to be slightly smaller. I got a pulley from TSC for a 1" spindle, cut the center out, and welded the old pulley's center in it. Thread is here.
  • Giantkiller said thank you
#3 Giantkiller OFFLINE
Giantkiller
  • 4 posts
Posted September 27, 2012 - 03:23 PM
The tag on the deck shows. #59840-23715.
The pulley measures 4" diameter.
1/2' ( or slightly bigger) belt groove.
the diameter of the center shaft measured 22mm ?
Thanks for any help.
This mower deck has a Large blade in the center and 2 smaller blades on the far sides.
#4 KennyP ONLINE
  • 37,461 Thanks
  • 45,483 posts
Posted September 27, 2012 - 04:05 PM
That is an earlier model deck. May take a bit to find your solution!
#5 KennyP ONLINE
  • 37,461 Thanks
  • 45,483 posts
Posted September 27, 2012 - 04:29 PM
Is this by chance an aluminum deck?
#6 KennyP ONLINE
  • 37,461 Thanks
  • 45,483 posts
Posted September 28, 2012 - 11:49 AM
I did some snooping at New Holland and found two different decks that use shorter outside blades, one is 09jc9738 & 9740. They want $40 for a pulley, but don't give a size. These were from 1968-71
