Hydrolic Help For 1973 Case model#222
2 replies to this topic
#1 allenmiller2310 OFFLINE
allenmiller2310
  • 8 posts
Posted August 02, 2010 - 06:41 PM
I have a Case 1973 model 222 serial#9690242 that came stock with the 12hp Kohlert hat has been severly modified for doing tractor pulls. The hydrolic pump, motor valce body and such are still all original.The motor is the only thing that has been changed. I pulled before in the 900lb. class on black top about 6 times and it did phenomenal every time. Before I competed in the latest pull in the 1050lb.class I was pulling a 12,000lb forklift up hill and spining the tires with ease. The eliminator is about the same to pull as the forklift. When pulling the eliminator I noticed a great reduction in torque and was only able to move the sled about 10ft. The hydro fluid was passing by somewhere making a squealing noise. Is there some kind of adjustment on the valve bank, hydro motor, or some kind of upgrade that anyone knows about to help me with. I am in desperate need of advise do to the next pull being a month away........Help me somebody!!
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 02, 2010 - 07:07 PM
First off welcome to GTtalk Allen.:welcome:
There are a lot of knowledgeable people here.
Second, It is best to post a single problem in only one forum.
You have several relies to your earlier post in the Case forum.
#3 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 02, 2010 - 07:19 PM
Welcome to GTtalk
