Drill Press Drive Belt
11 replies to this topic
#1 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted September 26, 2012 - 06:46 PM
I have a Craftsman floor mounted drill press that needs a new drive belt. Alas, I don't have the model #.
This machine has 8 speeds and one belt. It's a silly looking little belt, 3/16" X 40-something ". Anyone have anything like this to give me a model #???
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted September 26, 2012 - 06:50 PM
PART #91745 OR 1745 3/16" WIDE BY 45" LONG.
Gates 3V450 Nope, that one is 3/8" still looking.............
Okie-dokie, Gates 2L460 is only 1/4, but is 45.9 long. Reportedly works fine.
Also, sears has a replacement, but it is labeled as a 'timer knob'. I trust Sears as far as I can throw one of their stores.
http://www.searspart...=0&shdPart=1745
Edited by Cat385B, September 26, 2012 - 07:48 PM.
  • MH81 and LilysDad have said thanks
#3 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,266 Thanks
  • 6,071 posts
Posted September 26, 2012 - 08:28 PM
Also, sears has a replacement, but it is labeled as a 'timer knob'. I trust Sears as far as I can throw one of their stores.?!?!?!
HAHAHAHAHAHA :p
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted September 26, 2012 - 10:53 PM
You might try looking for metric belts. 3/16 is awful close to 5mm, maybe that's what it started out as.
something like a 5m by 1140 or so...
  • LilysDad said thank you
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 27, 2012 - 05:02 AM
If you take it to a belt supplier thay should be able to ID and size one for you.
#6 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted September 27, 2012 - 06:39 AM
Thanks much!!!
How can I give multiple thanks???
#7 KennyP OFFLINE
  • 40,925 Thanks
  • 47,117 posts
Posted September 27, 2012 - 07:48 AM
I think you just did!
#8 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted September 27, 2012 - 08:00 AM
No, to a single person! A couple of guys should get 5 each.
#9 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted September 27, 2012 - 09:14 AM
I have found that having some of this on hand, is real handy.
Accu-link or Powertwist drive belts :
There are at least two brands currently on the market:
PowerTwist belts, manufactured by Fenner Drives, are red.
Accu-Link belts, from Jason Industrial, are green. Posted Image
Edited by marlboro180, September 27, 2012 - 09:15 AM.
#10 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted September 27, 2012 - 01:56 PM
Good stuff on a table saw. Pricey though.
#11 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted September 28, 2012 - 10:17 AM
Yes LD, a touch on the spendy side, but seeing as I have had the same Acculink belt running on my tablesaw for nearly a decade , I think it is money well spent :-)
#12 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted September 28, 2012 - 12:14 PM
The best thing on a table saw, it doesn't take a set and run rough/vibrate.
