1980 Jd 210
14 replies to this topic
#1 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted September 26, 2012 - 10:51 AM
Well iv tried attaching pics a number of times and i dont believe it worked. A couple months ago i was given a 1980JD 210 & since then i have flushed the rearend, changed plug, fuel and air filters, oil & have greased everything. (i never trust anyones else's idea of maintenance). It runs great, variable speed even works well although it does hesitate at low settings & sometimes doesn't allow tractor to move at all. The cover over the shift knob is missing & looking down i can see a pulley that wobles all over the place & i usually have to wait a couple seconds after pressing clutch in for the pulley to stop then i can put into gear. Can this pulley be tightened? I haven't even looked to be honest & i have owned many garden tractors but this is my 1st JD & iv learned in the past its better to ask others first. Thank you in advance.
#2 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted September 26, 2012 - 11:26 AM
First off... Do you know if the variator sheave has ever been lubricated with graphite? Some of the symptoms you mention were similar to those I experienced on my RF 110. I used and alcohol-based spray graphite lube that I picked up a my local NAPA to fix the problem. I sprayed the stuff on the shaft inside the variator assembly and gave it a drive. Noticeable improvement.
Second... Not sure which pulley you are referencing. What is the serial number of your tractor. I would like to help but JDParts.com shows a production change with tractors beginning with serial number 95,001.
Thanks for the new thread! :thumbs:
#3 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted September 26, 2012 - 12:20 PM
Trav- you posted a diagram that had all the pulleys numbered. Its pulley #11. Im at work and dont have the serial number with me right now
  • Trav1s said thank you
#4 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted September 26, 2012 - 12:35 PM
Ok... I will grab that and post it in this thread for reference. :thumbs:
#5 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted September 26, 2012 - 12:39 PM
#6 KennyP ONLINE
  • 38,399 Thanks
  • 45,943 posts
Posted September 26, 2012 - 01:10 PM
Farmlife, welcome again!! Try using this to upload pics, remember they should be .jpg or .jpeg.
#7 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted September 26, 2012 - 01:55 PM
Item 11 is an idler/tensioner. On the old RF 110 it is not loose. Since the 200 series is the evolution of the RF machines I think it's safe to say it should not move. The easiest way to get to it is to remove the fender pan that the seat is attached to. Once that is gone you can easily get right to everything.
Another option for pics it to consider hosting them on a site like photobucket.com and direct link the file address using the image feature.
  • Farmlife said thank you
#8 KennyP ONLINE
  • 38,399 Thanks
  • 45,943 posts
Posted September 26, 2012 - 02:03 PM
Trav1s, we would rather a direct upload. If anything happens to the link, the pics are gone forever.
#9 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted September 26, 2012 - 02:16 PM
I have to use tapatalk to post pictures but that is because I use apple products. As far as pulley the guys are right it should not wobble. It can be change from under the tractor, but taking fender pan off makes it easier.
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 26, 2012 - 05:34 PM
I am using a Mac Mini and don't have any trouble posting pictures. Are you using an older machine/OS?
#11 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted September 26, 2012 - 07:11 PM
I've attempted doing it from my Samsung Galaxy smart phone since thats where the pics are. The files are listed as "jpg" & are small enough however it still wouldn't upload them. It did however upload a pic i had downloaded and saved from the internet im not sure why.....i'll figure it out & i love to take pics of "toys"...lol, so be ready....
#12 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted September 26, 2012 - 07:14 PM
Guess what????? I figured it out....apparently my thumbs are too fat and i was hitting the wrong buttons..."dooooh"20120823_200715.jpg 20120823_200703.jpg
  • KennyP and Trav1s have said thanks
#13 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted September 26, 2012 - 08:07 PM
Farmlife
it looks like you are missing a brake pedal.
if you need one let me know.
I can send you one for a cheap price plus shipping
have fun with the 210
#14 KennyP ONLINE
  • 38,399 Thanks
  • 45,943 posts
Posted September 27, 2012 - 05:59 AM
Glad you were able to get the pics uploaded. Nice tractor!
#15 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted September 27, 2012 - 06:36 AM
Thanks....hey nuthn beats FREE!!
